Peeling Clean on Aluminum Wheels - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by brendonv, this thread has received 14 replies and been viewed 9695 times.
post #1 of 15 (permalink) Old 09-26-2009, 01:06 AM Thread Starter
brendonv's Avatar
Is there any fix for peeling clear coat on factory aluminum wheels?
Early 1999 F350 DRW Dump, 6spd 4x4, 4" Turbo Back and DIY Intake
Early 1999 F350 SRW 8' Box, 6spd 4x4 Stock
brendonv is offline
post #2 of 15 (permalink) Old 09-26-2009, 02:01 AM
Other than stripping the clearcoat off, then either polishing the bejeezus out of it or re-clearing in, I can't think of a fix...
jvencius is offline
post #3 of 15 (permalink) Old 09-26-2009, 12:12 PM Thread Starter
brendonv's Avatar
Might have to do that. Wondering what the best way to strip it without damaging them.
I'm getting the whole set of OEM Dually wheels for $300.
brendonv is offline
post #4 of 15 (permalink) Old 09-26-2009, 12:18 PM
rock removal technition
what are ya doin with the old ones
double-s-diesel is offline
post #5 of 15 (permalink) Old 09-26-2009, 03:33 PM
Zrock's Avatar
I would just send them to a rim shop for repairs. I just got my rims back from repair and to fix 2 bent rims strip and reclear all 4 rims was about $150. even any good body shop should be able to do it for cheep
Zrock is offline
post #6 of 15 (permalink) Old 09-26-2009, 10:47 PM Thread Starter
brendonv's Avatar
I was thinking of getting them media blasted, then they'd be a brushed aluminum look from what I understand. I could always just polish them if needed.
The guy I got them from said he found a place that did his buddies for $50 a pop. The fronts are mint but the backs have spots.
The old ones are steel, I'm going to keep them around.
brendonv is offline
post #7 of 15 (permalink) Old 09-27-2009, 12:18 AM
If you're going to do that, you might want to have them powdercoated--I had a set of 16x8 Welds blasted, heated, then hot-sprayed for $65/each and powdercoat will almost certainly hold up better than clearcoat.
jvencius is offline
post #8 of 15 (permalink) Old 09-27-2009, 02:39 PM Thread Starter
brendonv's Avatar
I'm not sure I want to deal with clear coat in the future. The fact of the matter is I will always be near salt, and that's what kills these things in winter once you get a little scratch it finds it's way underneath.
I found this stripper, which the previous owner also mentioned to me. It'll strip them bare, then I'll have to maintain the polish. The truck get used 2-3 times a week in summer, and can sit for weeks on end in winter. I'm pretty sure I won't mind a quick wash and polish, as I've done it before in the past.
I might go this route, just trying to do it on the cheap as I never thought I'd find a set of these rims anyways.
http://www.buschshineproducts.com/in...age=page&id=22
brendonv is offline
post #9 of 15 (permalink) Old 09-27-2009, 03:09 PM Thread Starter
brendonv's Avatar
New bling.
brendonv is offline
post #10 of 15 (permalink) Old 09-27-2009, 03:23 PM
Zrock's Avatar
Well those wont be to bad to polish.. I was thinking of my old rims they were a nightmare to polish
Zrock is offline
Polishing Aluminum Wheels. CFRO The Detailing, Paint & Bodyshop 9 02-09-2009 10:35 PM
Chrome Peeling on Eagle Wheels MattBMiller General Ford Truck and Excursion 4 10-09-2006 05:55 PM
Aluminum Wheels fordt Towing and Hauling 2 03-20-2006 01:30 PM
Two aluminum wheels 16x? with 8x6.5 pattern... steved Whats Been Sold 5 02-21-2006 06:32 PM
aluminum vs steel wheels dondiesel444 Medium and Heavy Duty 17 10-16-2005 04:27 PM
