HID Conversion kit any have them??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by littlebigrig6.0, this thread has received 16 replies and been viewed 1123 times.
post #1 of 17 (permalink) Old 09-26-2009, 06:05 PM Thread Starter
little big rig 6.0
Im looking to replace my 04 250 headlight with the 05-07 set and get hids for them, does any one have hid conversions in their truck, if so how do you like them and where did you get them. Their are so many different one out their, and so many different prices, I want to make sure im buying a good set. Im looking for the ones that look like the high end cars. Thanks guys
6.0l, bully dog triple pup, dual 5"bull hauler stacks, strait pipe from turbo back
littlebigrig6.0 is offline
post #2 of 17 (permalink) Old 09-26-2009, 08:06 PM
SSpeeDEMONSS's Avatar
i believe matt and darin have them.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #3 of 17 (permalink) Old 09-26-2009, 08:56 PM
TxFireman1972's Avatar
I just did them in mine and LOVE them. I did the Bi-Xenon kit so I could retain my high beams. I did the 6000K bulbs, because any higher and they get a little too blue for me. Here is the info from a post I had on another site from when I put them in:
Picked up a set of Bi-Xenon 6000K HID's for my truck. Got a chance to put them in today. Very simple install. I went with Bi-Xenon to maintain my high beams (mainly for flashing if I need to). The Bi-Xenons actually have a motor in them that move the bulb up and down to maintain the ability to have high beams. Here is some really good info on Bi-Xenons:
Bi-Xenon HID Kit [Bi-Xenon]
I am very pleased with them so far and anxious to see them tonight. Here is the actual kit I put in (forgot to take an open box pic to show the contents).
Here are the harness diagrams:
Main Harness:
Additional Harness needed for the bi-xenons for the highbeams:
2005 F350 Crew Cab 4x4
PMF Rear Leaf Spring Conversion w/2011 Leaf Springs
20" Harley Wheels 305/55/20 Nitto Terra Grapplers
ARP Studs & EGR Delete from PowerStrokeMagic w/GearHead Tunes
Amp Research Steps, MBRP
TxFireman1972 is offline
post #4 of 17 (permalink) Old 09-26-2009, 08:57 PM
Took me about an hour, but thats only because I hide all my wires and want everything perfect. I picked them up from a friend of mine that owns a local shop.
post #5 of 17 (permalink) Old 09-26-2009, 09:03 PM
TwinStacks
SmknDzl's Avatar
They are usually plug and play so easy to put in. The higher the kelvin number the less lumen they are and the more exotic the color. I agree with TxFireman1972 on getting the ones that retain the highbeams. As far as brand goes the cheaper they are they tend to flicker when cold and burn out sooner. The more expensive sets usually give more lumen with the same kelvin number. I am very happy with mine
Chris Cayer- www.facebook.com/SmknDzl or www.myspace.com/smkndzl send a request
Early '99 Black Lariat F-350 cclb dually-TS 6 position, AFE StageII, Autometer UltraLite Gauges, 6" Turnout Stacks, Muffler/Cat Delete, Built Trans from RacerX with .670 Line Mod Valve and Full LockUp Valve, 6.0L Trans Cooler, Boost Relief Valve, Oil X-Over, 5% Tint Around With 20% On The Windshield and 5% Strip On Top, Tinted Tail Lights, 2003 Clear Headlights, VisionX 8K H.I.D. Kit, JVC InDash DVD, APS997 Remote Start and Alarm, Painted Grille and Mirrors, WhiteNight Reverse Lights
Competition Cobra29, DaveMade Comp 2x2, 2x4 and 5pill boxes on VOLTS, Modified Wilson 5000...YEAH IM TALKING
Nathan Airchime P5 Train Horns @ 200PSI
SmknDzl is offline
post #6 of 17 (permalink) Old 09-27-2009, 01:45 AM Thread Starter
little big rig 6.0
can you guys get some pics of them on, that would be great, so I am assuming, with out the Bi-Xenon you don't have a high beam, I was wondering how the high beam works, since my factory bulbs have the high and low beam in one, also are they much brighter then halogen bulbs
post #7 of 17 (permalink) Old 09-27-2009, 01:49 AM Thread Starter
little big rig 6.0
I just went on the site www.carhidkits.com, and still cant figure which ones to buy, Whats the difference
post #8 of 17 (permalink) Old 09-27-2009, 03:08 PM
TwinStacks
SmknDzl's Avatar
I dont know why its blurry but here are mine...
SmknDzl is offline
post #9 of 17 (permalink) Old 09-27-2009, 03:19 PM
TwinStacks
SmknDzl's Avatar
My set has two bulbs attached to the same plug so the high and low work. Other sets have angle changing bulbs and some just dont use the highbeam.
The Bi-Xenon on carhidkit have two filaments and a motor to change the angle. That set does have highbeam action
SmknDzl is offline
post #10 of 17 (permalink) Old 09-27-2009, 09:47 PM Thread Starter
little big rig 6.0
Do you think I need the high beam, aren't theses things supposed to be bright enough?
03-06 conversion topflight250 2003-2007 6.0L Power Stroke 2 03-19-2009 10:04 AM
4WD conversion TLadd 1994-2003 7.3L Power Stroke 5 03-18-2009 11:32 PM
conversion or buy used?? jmccall Diesel Conversion 12 10-08-2007 10:14 PM
10 lug conversion AllOut0606 1994-2003 7.3L Power Stroke 13 10-02-2007 12:30 AM
SD Conversion moonshiner General Ford Truck and Excursion 0 08-18-2007 01:16 AM
