Thump in front end - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Texaspsd, this thread has received 9 replies and been viewed 955 times.
post #1 of 10 (permalink) Old 10-07-2009, 10:18 PM Thread Starter
Thump in front end
I need some help with this problem. Whenever I turn sharply, I get a "Thump, thump, thump" in the front end. It is worse when turning right than left. It sounds like it is on the drivers side. I can feel and hear it. So far I have changed the upper and lower ball joints (drivers side), the u-joint (drivers side) and the end of the drag link(not sure what to call it). I also just replaced the front hubs (it was thumping before I replaced them). Can anybody give me some ideas on what this might be?
OLD: 2002 F-250 Crew Cab 4X4, 310,000 miles, 4" Exhaust, Pyro and Boost Guages, DP Tuner 40Tow and 80Econo NEW: 2011 King Ranch Royal Red Metallic
Texaspsd is offline
post #2 of 10 (permalink) Old 10-07-2009, 10:22 PM
TDG MAFIA MEMBER #77
TooLoudTooBad's Avatar
Have you checked the track arm bar? It is the rectangular piece that runs from the frame to the axle. The bolt on the axle side can come loose and obround the hole. I ended up replacing the bolt with a larger size and sinching it down to about 400 ft pounds. No thump since.
TooLoudTooBad is offline
post #3 of 10 (permalink) Old 10-07-2009, 11:00 PM Thread Starter
I have not checked it, I will look at it see. Could you move it around with the truck just sitting there or did you have to jack it up?
Texaspsd is offline
post #4 of 10 (permalink) Old 10-08-2009, 11:16 PM
You shouldn't be able to move it at all by hand. Torque the bolts down as tight as you can get them (Over 120 Ft #'s) and see if your thumping sound goes away.
post #5 of 10 (permalink) Old 10-09-2009, 01:18 PM
Mod Friendly Title
Zaairman's Avatar
Try replacing your sway bar bushings with a set from Energy Suspension.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #6 of 10 (permalink) Old 10-09-2009, 03:21 PM
I screwed up and typed in 120 ft pounds. It should be over 200 foot pounds.
post #7 of 10 (permalink) Old 10-11-2009, 11:53 PM Thread Starter
Check the front end parts, they all seem OK. The guys at the shop put it up on jacks and engaged the 4 wheel drive. Made the noise really bad in 4X just by turning the wheels. Looks like there is something in the differential. Any ideas on that? Headed to the differential shop this week.
Texaspsd is offline
post #8 of 10 (permalink) Old 10-16-2009, 12:29 AM Thread Starter
Differential and Transfer Case both check out ok. Still looking for cause.
Texaspsd is offline
post #9 of 10 (permalink) Old 10-16-2009, 12:30 AM Thread Starter
How hard is it to replace the bushings on the sway bar and springs? All of the bushings are original.
Texaspsd is offline
post #10 of 10 (permalink) Old 10-16-2009, 01:11 PM
Mod Friendly Title
Zaairman's Avatar
Sway bar bushings aren't bad, you'll need a ball joint press to do it.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
Head studs done and now a strange thump. EJ Krueger 2003-2007 6.0L Power Stroke 9 09-15-2009 03:51 AM
changing front main and front cover gasket, need advice SSpeeDEMONSS 5.9L Cummins 12 Valve (1994-1998.5) 30 07-17-2009 03:21 AM
frontend thump druman32 1994-2003 7.3L Power Stroke 18 02-13-2008 08:18 PM
Massive Thump every time I turn the steering wheel Nomaprd 1994-2003 7.3L Power Stroke 14 05-03-2007 12:31 AM
coasting in neutral...then thump? tdmr1195 2003-2007 6.0L Power Stroke 8 08-04-2006 04:29 PM
