Did a brake fluid flush and wooooow - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dayusex, this thread has received 19 replies and been viewed 2545 times.
post #1 of 20 (permalink) Old 10-11-2009, 05:54 PM Thread Starter
I can count to Potatoe
So my truck when you got hard on the brakes the steering wheel would shudder and the backend would get a tad squirly. I thought maybe warped rotors but took them off and checked and they were legit. So then I checked my brake fluid and it was darker then the bath water after my wife "relaxes". So I went to autozone and bought valvoline synthetic brake fluid. Suctioned out the MC, filled with clean fluid, then bleed the brakes starting at the rear passenger, rear driver, front passenger, front driver. What freaked me out was the first bit of fluid out of each caliper had a bunch of black chunks and air. So after all is said and done took it for a drive, pedal feels 1000x better, stopping is better, and best of all the steering wheel no longer vibrates. So if you have that issue you might wanna check your brake fluid!
dayusex is offline
The Following 2 Users Say Thank You to dayusex For this addition to TDG:
drgriff (10-29-2009), John_G (10-25-2009)
post #2 of 20 (permalink) Old 10-12-2009, 01:12 AM
Haulin' Hay
NCfarmboy's Avatar
Thats great advice. I changed mine last year, and plan to do it again this winter. I noticed a big improvement in braking as well.
NCfarmboy is offline
post #3 of 20 (permalink) Old 10-12-2009, 03:37 PM
Saftman's Avatar
Had mine done also about 2 months ago. Very noticeable improvement.
Saftman is offline
post #4 of 20 (permalink) Old 10-19-2009, 07:00 AM
how much should something like that cost for people that don't know how or cant do it them self?
EJ Krueger is offline
post #5 of 20 (permalink) Old 10-19-2009, 03:31 PM
I paid just under a c-note to have mine done before we moved this past summer...
jvencius is offline
post #6 of 20 (permalink) Old 10-20-2009, 01:45 AM Thread Starter
ahhh people it costs about 12 dollars in fluid. If you have a 10mm wrench some spare 3/16th hose and a turkey baster you can do it in an hour or less!!!
dayusex is offline
post #7 of 20 (permalink) Old 10-20-2009, 01:46 AM
NGHTRGR's Avatar
Doing Hawk LTS pads, rotor turn, Valvoline Syn Brake Fluid, and bleed this weekend on all 4 corners. Should be a good time hopefully the forecasted rain cooperates.
Black 05 Excursion -MBRP T-Back minus kitty, Airaid w/Zoodad, FS2500, Coolant Bypass, ATS Headstuds, ITP Reg Rtn, Full EGR Delete, DFUSER Light Harness, Keystone Heat Extractor Hood 2 Tone, CCV Reroute, 4-6" lift, 35" MT Baja MTZ's on Classic Locks, SCT X2 w/Innovative Extreme Race
NGHTRGR is offline
post #8 of 20 (permalink) Old 10-20-2009, 01:47 AM Thread Starter
should be easy just remember to open the bleeder screws when you compress the pistons
dayusex is offline
post #9 of 20 (permalink) Old 10-20-2009, 02:51 AM
If it had 'chunks' out of the calipers it is time to do flex hoses.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
post #10 of 20 (permalink) Old 10-22-2009, 01:18 AM Thread Starter
Yeah I was debating if it was time for that or not. It brakes so smooothly now haha.
dayusex is offline
Brake Flush nevrknow General Ford Truck and Excursion 7 10-02-2009 03:22 PM
fluid flush?? brake and power steering Strokin05 2003-2007 6.0L Power Stroke 4 03-05-2007 05:58 PM
Flush power steerind and brake fluid?? Strokin05 General Ford Truck and Excursion 6 03-05-2007 08:26 AM
Tranny fluid flush Motown Fire 2003-2007 6.0L Power Stroke 4 04-19-2006 01:26 AM
Transmission Fluid Return Line (flush question) Bear Hunter 2003-2007 6.0L Power Stroke 22 11-02-2005 09:40 PM
