Nathan Train Horns - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Cajunsuperduty, this thread has received 13 replies and been viewed 2455 times.
post #1 of 14 (permalink) Old 10-14-2009, 06:32 PM Thread Starter
Swamp Land Member
Cajunsuperduty's Avatar
Images: 12
Nathan Train Horns
I have uploaded the Nathan Train Horn pics in the Gallery. They may be a little more easy to find there. Should be able to find them by searching, Train Horns, Nathan, K3 or Trainhorns. I cannot begin to explain how much joy these things can bring. At least for the person pulling the lever.
I have no idea how to copy them from the gallery to this post. Still need to take a couple of more pics of the tank and compressor which are also concealled underneath.
Ken
04 Superduty FX4
Superchip, 4" Stainless MBRP Turbo Back No Cat, No Muffler, Zoodaded, 4.5" Donahoe Racing "Edge" Hanger Kit Donahoe Racing "Edge" Signature Series Shocks, 35x12.50-18 NITTO Trail Grapplers, 18" Moto Metal 951's, Acetoned Badges, High Idle Mod, smoked cab light lenses, 05 Grill, Nathan K3's Custom Mounted Underneath, Graham White Valve, 7.5gal Air Tank, Viair 480C.
Cajunsuperduty is offline
post #2 of 14 (permalink) Old 10-14-2009, 06:37 PM
is here and there.
Rcannon's Avatar
Images: 11
Some of the images shown below.
See more here > https://thedieselgarage.com/gallery/b...imageuser=8152
Rcannon is offline
The Following 2 Users Say Thank You to Rcannon For this addition to TDG:
Cajunsuperduty (10-14-2009), Hellbilly (10-21-2009)
post #3 of 14 (permalink) Old 10-14-2009, 06:42 PM
Administrator
fordt's Avatar
Images: 5
nnnnnnnniiiiicccccccccceeeeeeee!
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
post #4 of 14 (permalink) Old 10-14-2009, 06:43 PM
Administrator
fordt's Avatar
Images: 5
I think someone was just asking about a lever like that.
-Wayne
fordt is offline
post #5 of 14 (permalink) Old 10-21-2009, 04:42 PM
Where did you get that lever?
[CENTER]1995 PowerStroke 4x4 - 1968 Bronco
#27
Big Stroker is offline
post #6 of 14 (permalink) Old 10-21-2009, 07:19 PM
Hellbilly's Avatar
That is sweet....I gotta get me some of those horns...
AMERICAN CLUB #43
WALNUT CLUB
BOMB SQUAD
RIDIN' DIRTY CLUB #54
WEST COAST POWERSTROKERS #9
SINGLES CLUB #256
Though more painful, there is more dignity being under the bus than under the desk.....at least under the bus, you're only swallowing a little pride....
Hellbilly is offline
post #7 of 14 (permalink) Old 10-22-2009, 01:52 AM
Haulin' Hay
NCfarmboy's Avatar
Truly awesome! Nice work!
NCfarmboy is offline
post #8 of 14 (permalink) Old 10-23-2009, 06:44 PM Thread Starter
Swamp Land Member
Images: 12
I bought the valve/lever on Ebay. You can usually find on on there. You can also get one from airhornsoftexas.com. This is a Graham White 353 Series copy cat valve. You can search on Ebay by train horn valve or Graham White valve usually find one. The one I have is the copy cat version. I have had both and there is really no difference in performance. They both make you smile when you pull the lever, . This is the same valve that they put in locomotives. It worked out really good, as I ran my 1/2" diameter air brake style hose straight back thru two drilled holes in my console then thru the floor board inside my console.
Ken
04 Superduty FX4
post #9 of 14 (permalink) Old 10-27-2009, 02:05 AM
I do all my own stunts
Send a message via MSN to kblackav8or
It's a no-no to drill through your frame flange like that. If you do a lot of hauling I would keep an eye open for cracks forming. There is a formula on where to drill through c-channel frame rails. You can clamp to the flange all you want just not putting holes in it that didn't come from the factory. You may never have a problem but it is risky if you work your truck hard.
2000 F-250 PSD 6 speed 4x4 Lariat
1959 Kenworth CC 925 NTC-400 5x3 4.10 SQHD's
Myriad of parts and pieces in my garage
kblackav8or is offline
post #10 of 14 (permalink) Old 10-28-2009, 04:02 PM Thread Starter
Swamp Land Member
Images: 12
Mechanical Engineer here. There is no reduction in load capacity or stress concentration points or stress risers that are more conducive to cracking due to the 3/8" holes that were drilled thru the frame for the horns. This of course is based on some finite element analysis done thru a solid modeling program, however there are some stress concentration points that show up around some of the factory holes when the frame is "heavily overloaded". I don't do any heavy hauling with my truck, but even if I did there would be absolutely no risks associated with these holes, but thanks for the concern.
Ken
04 Superduty FX4
Train horns Snake Ford - Modification instructions, Product installs and Tech Articles 60 01-31-2015 04:00 PM
Nathan K3 Train Horns Cajunsuperduty General Ford Truck and Excursion 1 10-14-2009 03:04 AM
Train Horns done!!! CSIPSD General Ford Truck and Excursion 10 02-03-2008 01:50 PM
train horns SSpeeDEMONSS The Parking Lot 42 10-07-2007 01:17 AM
Train horns on a SD? Foxx General Ford Truck and Excursion 2 09-23-2007 11:44 PM
