Making 92 F350 auto into a manual tranny - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by OzarkSaints, this thread has received 2 replies and been viewed 1311 times.
post #1 of 3 (permalink) Old 10-16-2009, 03:56 AM Thread Starter
found a 92 F350 4x4 that fits all my requirements except it is an automatic, which I am ok with, simply prefer stick shift......anyone have a rough idea how much money it'd cost to put a manual tranny in her and if there are any issues with doing so? I would most likely just wait til auto trans started acting up in the future and then swap, just trying to figure out what I'd be getting myself into before making the decision to purchase.
OzarkSaints is offline
post #2 of 3 (permalink) Old 10-20-2009, 12:43 AM
91/2 7.3idi's Avatar
Send a message via AIM to 91/2 7.3idi
when i did mine i just bought a whole parts truck for 1000, plus 250 to have it towed home. but i also sold a lot of parts off it and then took it to the scrap yard and got like 300 bucks. a parts truck is probably your best bet.
Nick
91 f-250 xcab,long bed,7.3 idi(soon to be a dt 360) 5 speed, 33's, pump turned up, ultra-lite gauges and 6 inch flat black miter cut stacks. coming soon:turbo and intercooler.
97 gmc 2500 2x4 6.5 turbo 5 speed. k&n intake and muffler cut off. gone but not forgotten
01 gmc 2500hd duramax xcab long bed 4x4. straight piped
91/2 7.3idi is offline
post #3 of 3 (permalink) Old 10-27-2009, 03:24 AM
I do all my own stunts
Send a message via MSN to kblackav8or
Keep an eye on Craigslist. The ZF5's come up regularly. See if you can get one with the transfer case as a unit. You will need to pull up you carpet. The spot where the shifter comes through should be visible. In those days they had a juice clutch. Not sure on the F models but you may look at the pedal assembly. If there is a spot to hang the clutch pedal, it will save you a bunch of trouble. You may only have to trim the brake pedal to match a manual brake pedal pad. Not sure but I have done this on other Fords. The other one I did it turned out only the metal pad was wider and the rest of the pedal assmbly was the same. There used to be a reinforcement panel for the clutch master on the firewall. Get one of those or augment it so you don't have issue. I am not sure but the manual transmission engines may have a slightly different cam in them. You may have exhaust issues and have to deal with that. I would open up the transmission before you install it to make sure it is sound.
2000 F-250 PSD 6 speed 4x4 Lariat
1959 Kenworth CC 925 NTC-400 5x3 4.10 SQHD's
Myriad of parts and pieces in my garage
kblackav8or is offline
Auto -to- manual tranny swap MadvilleMustangs 5.9L Cummins (2003-2007.5) 2 06-13-2009 02:58 PM
Changing Tranny Auto To manual powerstroke7.3 1994-2003 7.3L Power Stroke 5 02-07-2009 03:07 PM
tranny rebuild kits! need help asap tranny is shot...f'in dodge auto trans blksmk 5.9L Cummins 12 Valve (1994-1998.5) 5 12-26-2008 10:55 PM
auto to manual tranny swap STROKETHIS7.3 1994-2003 7.3L Power Stroke 0 01-16-2007 01:15 AM
Auto Or Manual? BASIC Sled Pulling 4 06-18-2005 01:00 AM
