correct tire pressure for 37x13.50x20 toyo tire - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by skter97, this thread has received 15 replies and been viewed 36962 times.
post #1 of 16 (permalink) Old 10-23-2009, 03:12 PM Thread Starter
Send a message via Yahoo to skter97
What air pressure r u guys running n ur 37 toyos, I'm just put 45 in mine and it feels weird drivn it now, I can't remember what I had before
http://performancebyhenry.com/index-videos.php
2008 F250 FX4 ECLB, ALL RECONED OUT, S&B INTAKE, 6 INCH FABTECH LIFT WITH 37 TOYOS ON 20X10 HELOS WHEELS MAXX 8 CHROME, SPARTAN TUNED WITH THE 310!! 5 INCH MBRP COOL DUAL SS EXHAUST, SUPER DUTY LETTERING INSERTS, 6K HID BI-EXENON LIGHTS AND 6K BI-EXENON FOG LIGHTS, 5100 BILSTIEN SHOCKS, SHOCKER 152DB HORNBLASTER KIT!!,MORE TO COME,MAYBE A SPEARCO INTERCOOLER AND MAYBE SOME NOS
skter97 is offline
post #2 of 16 (permalink) Old 10-23-2009, 04:24 PM
O2ShootTheJ's Avatar
read the side of the tire
Singles Club #222
December 2008 TOTM
Riding High Club #2
2008 Truck of the Year
Ridin' Dirty Club #2
Big Thanks to:
O2ShootTheJ is offline
post #3 of 16 (permalink) Old 10-23-2009, 05:03 PM
Hellbilly's Avatar
I run 40 when not towing....50 when towing....I have the AT's...I ran my last set at 50 most of the time and the tires wore in the center really fast....
AMERICAN CLUB #43
WALNUT CLUB
BOMB SQUAD
RIDIN' DIRTY CLUB #54
WEST COAST POWERSTROKERS #9
SINGLES CLUB #256
Though more painful, there is more dignity being under the bus than under the desk.....at least under the bus, you're only swallowing a little pride....
Hellbilly is offline
post #4 of 16 (permalink) Old 10-23-2009, 06:17 PM
ZeroOne's Avatar
Depends on your rim width, vehicle weight, etc etc. Have any chalk? Make a thick line across the treads, air them up, then back off to where the line wears evenly across the entire width of the tread.
My tire size is different so these numbers wont work exactly, but just as an example, 38x15.50 on 20x10s on a Diesel/CC/SWB need 50(max) front and 33 rear.
ZeroOne is offline
The Following User Says Thank You to ZeroOne For this addition to TDG:
Hollywood (10-26-2009)
post #5 of 16 (permalink) Old 10-24-2009, 12:34 PM
I would think the load range D or E will play a big factor as well! I too would read the sidewall of the tire and see what it says for max pressure and then maybe back that number off by 5-10 psi depending on load on truck.
smoxy is offline
post #6 of 16 (permalink) Old 10-24-2009, 03:32 PM
Ford F250 Dude
Jus Cruisin's Avatar
Mine are 22's load range e and I run 60-65 in mine.
2008 Ford F250 4X4 Lariat Crew Cab Short Box 37x13.5x22 Toyos, KMC XD wheels, BDS 6" lift, tuned up.
Other toys:
2008 Roush 428R Mustang - Supercharged
2008 Corvette convertible
2009 Harley Davidson FLTRSE3 Road Glide
Jus Cruisin is offline
post #7 of 16 (permalink) Old 10-25-2009, 05:34 PM
R.I.P. DAD
SEABEE08FX4's Avatar
45-50
R.I.P. TMCS (SS) Brooks R Newell, I will forever miss you.
OneBigAssMistakeAmerica
2008 F-250 FX4
NMCB-28, KICKIN BUTT SINCE 1942
American club member #40
FOSP Club # 1
My sense of humor is an acquired taste, if you dont like it....... ACQUIRE some taste.
SEABEE08FX4 is offline
post #8 of 16 (permalink) Old 10-25-2009, 10:17 PM
Superdutytd's Avatar
Images: 3
Read what the max pressure says on the side of the tire?
2008 Red CCSB 6.4 Auto Lariat.
Stock 20's wrapped in 35x12.50R20 Toyo MT's, 3.73 gears, Nav, Backup Cam, Tailgate step, Upfitters, etc.
Mods: AFE Intake, Line-X, 20% Tint, Clear Bra, Husky Mats, Smoked Recon Mirror markers/3rd brake light, Bushwacker Pocket style flares w/ mud flaps + an aluminum Rapid Hitch (one of the best investments!)
Feel free to PM with any questions about any of my mods.
SRW Club #55
American Club #55
Last road trip-567 miles @ 20.7 mpg @ 67mpg average speed.
Superdutytd is offline
post #9 of 16 (permalink) Old 10-26-2009, 04:45 PM
Wyoming Cowboy
BadSuperduty's Avatar
Images: 10
That's it and then you get out a calculator. I'll use Toyo MT 37-13.50-22's for an example because that's what I have.
Go weigh your truck (front and rear). Record those numbers - in my case 6200 front and 4000 rear. The side walls read on these Toyos (3420lbs. @ 65psi). Divide 65 into 3420 and you get 52.61. This means for every 1psi. of air pressure you can support 52.61lbs. of weight. Take your front weight of truck and divide 52.61 into that number (eg. 6200 divided by 52.61 = 117.8psi.). Take your answer (117.8psi) and divide by 2 because you have two tires up front which = (58.9psi). So in my case I should run at least 58-59 up font in each of my front tires.
Use the same method for rear...(eg. 4000lbs. divided by 52.61 = 76.03psi). in my case with a dually I divide four into my answer (76.03) which gives me (76.03 divided by 4 = 19psi). So each rear gets 19-20 psi. On SRW trucks 2 will be what you use as your divider.
This is how it was explained to me years ago and it works. I have 35k on my current set and they are maybe 45% worn and wear evenly. The correct air pressure will extend the life and stop that premature wear down the center of your tire (over inflation). Plus the ride is better and you can check this with the chalk method above and will see a complete foot print everytime.
Cheers,
2008 F-350 Lariat Dually;
450 wide track, Tow Boss pkg., 4.30 gears, 6" PC radius arm lift & traction bars, MX6 adj. res shocks, 37" Kumho MT's, 22" BDW Alcoas, Buckstop bumper and 16.5k warn, Defender roof rack & light cage, 4-9" Light Force lights, APM Ram air hood, AFE PG7, Spartan 310, PSer67 4" ceramic DP & 5" DOC/DPF delete, 5" MBRP Y Pipe w/8" stacks, Spearco IC, Suncoast solenoid.
NHRDA # 4758
2010 41' Cyclone Toy Hauler
2003 230 SX Stingray
I Love the smell of diesel in the morning...it smells like victory!
BadSuperduty is offline
The Following 3 Users Say Thank You to BadSuperduty For this addition to TDG:
Hollywood (10-26-2009), woodsman (10-26-2009), ZeroOne (10-26-2009)
post #10 of 16 (permalink) Old 10-26-2009, 08:45 PM
I like Pretty Girls!
Hollywood's Avatar
As Zeroone and BadSuperduty said its NOT AS easy as reading the side, I dont get as fancy as them I jsut go by feel. I change my pressure with weight, what I am driving in (Dirt, snow,ice pavement ect) and how it feels in the corners. In the winter I can be changing my tire pressure 2 or more times a week with what I haul (Sleds) or conditions (ice or dry pavemnet). With a 13.5 wide tire it makes a big difference in keeping you out of the ditch with ice/sluch on the road.
so there isn't any "right" answer you just have to make a edumacated guess
2008 F-350 Lariat
6" Lift Riding on 37x13.5 Toyos
Canadian Club Member #12
Hollywood is offline
37x13.50x20 on BMF 20x9 with Leveling Kit Only [email protected] 2008-2010 Body & Suspension 21 07-08-2009 02:40 AM
Tire pressure alex8888 2008-2010 Body & Suspension 0 05-18-2009 03:12 AM
Correct Tire Pressure for Dunlop RV Radial Rovers crappace General Ford Truck and Excursion 6 03-18-2008 02:21 AM
Will toyo 355-60-20 fit on 08? anyone got any pics with that size tire on there truck Hofmann025 2008-2010 6.4L Power Stroke 4 01-16-2008 02:55 PM
Tire Pressure ?... HawaiianSuperDuty General Ford Truck and Excursion 1 04-14-2007 01:30 AM
