Opinions on a V-10 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by pontiacross, this thread has received 13 replies and been viewed 1503 times.
post #1 of 14 (permalink) Old 10-24-2009, 12:34 AM Thread Starter
pontiacross's Avatar
Opinions on a V-10
I am getting tired of this little car I have been driving everyday and decided I needed another truck. I am thinking about buying a gasser because I don't live but a couple miles from work and other than that I still don't put a lot of miles on a vehicle.
I also need something capable of hauling my puller around in case my buddy that usually hauls me with his 02 7.3 cant make it.
I have been seeing quite a few v-10s that look to be real nice in my price range, but I have never been around one. how much worse fuel mileage wise are they than a v-8, also how are they for power and reliability?
if you have any other opinions let me know.
Thanks
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #2 of 14 (permalink) Old 10-24-2009, 12:48 AM
I drove a CC/LWB with a V-10 for work a while back and it had plenty of power for the trailers we pulled with it (~4K lbs.). Mileage empty wasn't too bad (don't remember the exact mpg though...) but mileage when loaded could only be charitably described as "wretched"
jvencius is offline
The Following User Says Thank You to jvencius For this addition to TDG:
pontiacross (10-24-2009)
post #3 of 14 (permalink) Old 10-24-2009, 02:05 AM
vcassens's Avatar
my dad had an 2x4 ex with the v8 and my uncle had a 4x4 F350 with a v10 they actualy got within 1 or 2 mpg diferance and the F350 was geting better both had 3.73 gears the problem with the v8 is that it is under powerd for that size of vehical. my dads ex got traded with almost 300 K on it and did pull alright but the V10 wold out pull it any day they are both good engins. Good luck with what ever you get
2004 ford F350 6.0L 6 speed manual,SCT live wire,south bend double disk clutch,short throw shifter fx4. Costome exhaust 4 inch turbo back to 5" homade stacks, banjo bolt mod, shimed regulator,custom leveling kit (not blocks) and air lift air bags with onbord air suply TRADED FOR
2006 ford F 250 Amarillo 4" turbo back other than that stock for now
singles club #206
bomb squad #67
Ridin' Dirty Club #65
vcassens is offline
The Following User Says Thank You to vcassens For this addition to TDG:
post #4 of 14 (permalink) Old 10-24-2009, 02:56 AM
StewySD's Avatar
I have a v-10 crew cab that i had since 2000 never any problems with it. Pull a 8500 Pound trailer with it from san diego to glamis over a hundred times.Got about 6 or 7 miles to the gallon pulling. And around town with no trailer about 10 miles to the gallon. They pull great just the gas mileage s cks.Butt all and all there good trucks.
2005 Fx4 8" 4.0 Fabtech lift with 20" Weld rims on
35's traction bars, 430 gears, ATS Stage 2 Injectors, ATS Aurora 3000, Turbo Banks Monster exhaust and inner cooler, Zodad, H11 studs, EGR delete,
E Powered Tuner, ATS 5 Star TC.
StewySD is offline
The Following User Says Thank You to StewySD For this addition to TDG:
post #5 of 14 (permalink) Old 10-24-2009, 02:58 AM
That jives exactly with my experience--the V-10 had more than enough power to comfortably haul/pull whatever we needed to move but it was one thirsty SOB...
jvencius is offline
post #6 of 14 (permalink) Old 10-24-2009, 04:22 AM
Official blowy uppy guy.
woodsman's Avatar
I get anywhere from 8 to 11 mpg unloaded and I don't even think about when it is loaded. Power on the 3 valve motors is improved as is fuel efficiency. The 2 valve heads make about 190 RWHP and the 3 valves make around 275 I think. I'm not sure on the three valve heads really. An aftermarket y pipe and tuning will gain 1-2 mpg and put you around 230 hp on the two valvers. The really cool thing about these motors is the torque they make is unreal for a gasser motor. It pulls not quite as well as a diesel, but derned close.
1999 F250 Triton 415 Gasser
10 strokin 4 smokin
#7 WALNUT member
#4 American club member
#200 Singles club member
#0 Lifted club member
Running Every Redlight On Memory Lane
Ask me about the new club!
woodsman is offline
The Following User Says Thank You to woodsman For this addition to TDG:
pontiacross (10-25-2009)
post #7 of 14 (permalink) Old 10-25-2009, 04:46 AM
Bigking's Avatar
I had a 2000 Excursion with the V10, I was lucky to get 12mpg out of it. I had 86k miles on it and blew a plug out of the 10th cylinder. Don't know what happened but I heard a loud knock and I though I threw a rod. Opened the hood and my ignitor was sitting on top of my engine. Went to NAPA and bought a new one and a new plug. It must have stretched the threads out. Had to put an old plug in that cylinder. Ran good for aboout 4 months then I sold it. About a month later blew another plug out and needed a new head. I drove it for 2 years with no problems, but after buying my 05' powerstroke I wouldn't go back to it.
05' F-250, Harley Davidson #2993, True Blue
SCT X2 programmer (innovative tuned), MBRP 4in turbo back SS Cool Duals, Gutted Cat, S&B cold air intake, 2" front 1" rear lift, 325x60x20 Nitto Terra Grapplers, Stock Harley 20" rims, Line X, 20% tint all around, Alpine Linear Sub system, 4k Sylvania Silver Star lights, Zoo Dad mod, line of fire by Recon, ARP head studs, RCD EGR delete, new heads, new Turbo, dual bilstein steering stabilizers, bilstein 5100 shocks all 4 corners, truxedo bed cover, Amsoil. U.S.C.G
Bigking is offline
The Following User Says Thank You to Bigking For this addition to TDG:
post #8 of 14 (permalink) Old 10-25-2009, 07:57 AM
4play's Avatar
the v-10 is basically a 5.4 v8 with 2 cylinders added. the reliability also follows the 8's the fuel mileage is not that bad considering a 5.4 is a turd when pulling loads a v10 has no sweat doing. i have seen 5.4's get 8-10 and working there butts off when a v10 will get 8 and cruise all day long (same load). the plug spitting thing is rare and has been seen on all the family engines. there is and insert style (cheap fix) that can be done without removing the head BTW
4play is offline
post #9 of 14 (permalink) Old 10-25-2009, 01:25 PM
Robts's Avatar
I have a friend that has had a v10 since 2000. Its a great motor and he has around 120000 miles on it. No problems. million times more realiable than 6l
This will be the onlytime I ever say this. He installed a banks header and ehaust that came with a new ypipe. The old ypipe is tiny and smashed from the factory. It think he got 2-3 mile improve ment with their kit....well worth it
2004F-SVT Lariat 2005 Cummins 5.9 conversion
August 2007 TDG Truck of the Month
Septmeber 2009 TDG Truck of the Month
2008 TDG Truck of the Year
2005 CR Cummins conversion with destroked motor mounts and tach module.
ARP Studs;Hamilton springs and pushrods
WickedDiesel DragonSlayer CP3 and 5x10.5 inj
Tsperformance MP8; Smarty S06 TNT-R
Speraco Inercooler; Opie Water by-pass;DTT intake elbow
Twin turbos
Grand rock 7" stacks
ATS Stage V 48re Transmission with billet output shaft and Co-pilot
Ford transfer case with ATS input shaft. Thanks to Sogrand for that
4.56 gears with Detroit truetrac. Custom Oasis Diff covers
FarmboyFabrication Ladder bars
(10) Autometer Gauges
6.5" Explorer Procomp lift with Fox Shox
37x13.5x22 Toyos with 22x10 Eagle wheels
2005 front end conversion with McColluch HID lights
Randy Ellias light bar with 4 procomp 130watt lights
Heat exchanger hood; limo tint, recon lights up top and on the mirrors
Optima. Yellow Tops; BilletBadges; Big special thanks to Walley at FTE
My Cummins conversion:https://www.thedieselgarage.com/foru...read.php?t=933
Robts is offline
The Following User Says Thank You to Robts For this addition to TDG:
post #10 of 14 (permalink) Old 10-25-2009, 02:54 PM
Bigking's Avatar
I disagree about the V10, but you know there is always a lemon out there, and I guess I bought it. But the way my 6L runs now I would drag my old V10 around any day.
Bigking is offline
opinions cwood22 5.9L Cummins (2003-2007.5) 13 03-15-2008 04:44 PM
Need some opinions 4cstr General Ford Truck and Excursion 8 05-13-2007 05:22 AM
03 6L opinions 03f250 2003-2007 6.0L Power Stroke 15 03-24-2007 02:02 AM
