Tire Rotation - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Traveler1, this thread has received 3 replies and been viewed 1116 times.
post #1 of 4 (permalink) Old 10-29-2009, 10:55 PM Thread Starter
Traveler1's Avatar
Tire Rotation
Thinking of rotating my tires this weekend and was wondering if someone could tell me the proper rotation???
2005 FORD F250 PSD 6.0L 4X4 35,XXX Miles
..........Recon Smoked Lenses all the Way
Traveler1 is offline
post #2 of 4 (permalink) Old 10-30-2009, 01:40 AM
Front to back. Cross the front tires going back unless they are directional. Obviously you can also call a local tire shop and I'm sure they can tell you.
Gdief is offline
The Following User Says Thank You to Gdief For this addition to TDG:
Traveler1 (10-30-2009)
post #3 of 4 (permalink) Old 10-30-2009, 01:49 AM
04 MT's Avatar
I think opinions will vary on this as there are many wives tales out there when it comes to rotations. I look at the tires to see what the wear pattern looks like. If ball joints and alignment are good, and you dont have a big difference in tread depth front to rear I will cross rotate front to rear. It allows the tires to spin opposite of what they just were doing. If you look really close at the front edge of your tread blocks you will see that they are slightly rounded verses the squared off rear portion of the tread block, I belive this helps traction on ice and snow when you have that sharp angle going forward.
Another option is to rotate front to rear but keep the tires on the same sides or you can switch side to side on the same axle to spin the opposite direction. I use the side to side rotate when the tires are about wore out keeping the best tires on the front. I have never rotated the spare into the mix because i've never had 5 matching wheels Oh and BTW, every 5,000 miles on rotates prolongs tire life.
04 F-350 CC SB 4x4 6.0 auto 08 tow mirrors no muffler. ARP studs, IPR gen 2 delete Coolant filter, ECT coolant Xcal3 with tunes from Matt at Gearhead. Swamps 58volt FICM. 89 Peterbilt 377 N14 Celect Plus with a 13 speed mostly stock
04 MT is offline
The Following User Says Thank You to 04 MT For this addition to TDG:
post #4 of 4 (permalink) Old 10-30-2009, 01:53 AM
NGHTRGR's Avatar
What the tire shop told me was rear tires come straight forward, front tires change sides and go back, I don't have a spare
Black 05 Excursion -MBRP T-Back minus kitty, Airaid w/Zoodad, FS2500, Coolant Bypass, ATS Headstuds, ITP Reg Rtn, Full EGR Delete, DFUSER Light Harness, Keystone Heat Extractor Hood 2 Tone, CCV Reroute, 4-6" lift, 35" MT Baja MTZ's on Classic Locks, SCT X2 w/Innovative Extreme Race
NGHTRGR is offline
The Following User Says Thank You to NGHTRGR For this addition to TDG:
correct tire pressure for 37x13.50x20 toyo tire skter97 General Ford Truck and Excursion 15 11-02-2009 06:25 PM
Reverse rotation 3208 cat engine french277 General Diesel 0 03-06-2009 08:01 AM
Dually Tire Rotation brendonv General Ford Truck and Excursion 6 11-25-2007 08:18 PM
Dually tire rotation Diesel Dog General Ford Truck and Excursion 8 10-20-2006 04:28 AM
Twins move hot prospect Liriano into rotation RSS Feeder The Parking Lot 0 05-16-2006 07:01 AM
