Back-up Sensor - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 4cstr, this thread has received 10 replies and been viewed 11279 times.
post #1 of 11 (permalink) Old 11-06-2009, 04:08 PM Thread Starter
4cstr's Avatar
Images: 35
Back-up Sensor
On our X...we've noticed that when we put it into reverse...the "OFF" light lights up on the switch. We can't shut the light off until we put the truck into drive.
I've read the manual that says if the "OFF" light comes on and stays on that there is a problem somewhere in the circuit. I've checked the individual sensors on the bumper...and visually they look ok. No frayed wires...everything plugged in, etc. Is there anything else I can do myself to try and determine where the problem lies before I need to take this into the dealership? Since my wife isn't used to driving something this size...she and I would prefer the backup sensor to be working.
~Dave~
4cstr is offline
post #2 of 11 (permalink) Old 11-06-2009, 04:26 PM
Banned
Listen to each sensor. It should be making a slight clicking noise. The one that doesn't is the road to go down. Mine don't work either. But that info was posted here in another thread. I have not tried it yet.
wastedwagesracing is offline
post #3 of 11 (permalink) Old 11-06-2009, 08:05 PM
I be Architect'n
I was able to test like this:
Key-on engine-off, place in reverse and lightly touch/press each sensor at the shiny plastic thingy, you should feel some clicking. If it doesn't click, swap it out.
IME, it is typically the outboard sensors as they take most of the brunt of water from the tires.
2K3 EXCURSION 7.3L 4x4 EDDIE BAUER 107K miles as of 06-13-07
AFE Stage II / 4" MBRP exhaust / DP-Tuner F5 (Stock, 60hp Tow, 80hp Econo, 120hp race & High Idle) / Quadzilla Commander/ATS Housing
Running homebrewed BioDiesel and custom SVO kit for 70k miles.:Thumbup:
Misc. Mods: ZooDad/By-Pass Oil Filter/203* T-Stat/Coolant Filter/HPX/CCV Reroute/Tranny Filter/Foil Delete/Stereo Stuff/ITP Reg Return/Non-EBPV Pedistal and Exhaust Housing/Adjustable Waste Gate Controller/
"If you love your motorcycle, set it free. If it comes back to you it was probably a high-side."
I'LL TRY TO KEEP UP, BUT THE EXCURSION IS A BIG GIRL AND BIG GIRLS DON'T LIKE TO MOVE FAST.
6_Myles is offline
The Following 2 Users Say Thank You to 6_Myles For this addition to TDG:
4cstr (11-06-2009), sotexy (11-06-2009)
post #4 of 11 (permalink) Old 11-06-2009, 10:55 PM Thread Starter
4cstr's Avatar
Images: 35
Awesome..thanks.
But another quick question. If placed in reverse and the switch says "off"...will the sensors still click?
~Dave~
4cstr is offline
post #5 of 11 (permalink) Old 11-07-2009, 12:33 AM Thread Starter
4cstr's Avatar
Images: 35
Well...I tried it. None of them felt like they were clicking. This looks like its gonna get expensive.
~Dave~
4cstr is offline
post #6 of 11 (permalink) Old 11-07-2009, 12:54 AM
I be Architect'n
After you put it in reverse, can you hit the button and un-illuminate the OFF? I was able to do that with mine.
6_Myles is offline
post #7 of 11 (permalink) Old 11-07-2009, 01:11 AM
I be Architect'n
Also, the sensors are universal. You can buy one and swap them around to try and find the short. They take just a couple of seconds to change out.
6_Myles is offline
post #8 of 11 (permalink) Old 11-07-2009, 01:17 AM Thread Starter
4cstr's Avatar
Images: 35
No...once in reverse the "OFF" will not go off no matter how many times we push the button. I thought I had read somewhere there was a module involved. Not sure where this module is...but it may be my culprit.
~Dave~
4cstr is offline
post #9 of 11 (permalink) Old 11-07-2009, 08:14 PM
4play's Avatar
Your park aid module (PAM) is behind the jack storage panel, on F series its beind the glove box. The system basically has shut down due to a fault, most of the time the fault exists in one or more sensors, rarely see a module failure. you might at least look at the wiring to the sensors and also check their connections. But to gain further and more accurate diagnosis you will need to find a scanner that can diag the park aid system
4play is offline
4cstr (11-07-2009)
post #10 of 11 (permalink) Old 11-08-2009, 01:17 AM
Originally Posted by 4cstr View Post
... This looks like its gonna get expensive.
Not necessarily, since you could do what I do for my pickup. All you need to do is just leave the drawbar in all the time and just back up until you hear the "thud", then pull forward a little...
jvencius is offline
Exhaust Back Pressure Sensor 4cstr 1994-2003 7.3L Power Stroke 27 04-07-2009 05:03 AM
Problem with back-up sensor alarm Joepel43 General Ford Truck and Excursion 2 03-01-2009 05:39 PM
Exhaust back pressure sensor King 2003-2007 6.0L Power Stroke 6 02-24-2009 02:45 AM
Back up sensor malfunction hopeful 6.0 General Ford Truck and Excursion 4 02-12-2007 08:47 PM
Exhuaust Back Pressure Sensor lukesdiesel 2003-2007 6.0L Power Stroke 9 09-22-2005 12:46 AM
