excursion brake replacement - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Jarods gerbils, this thread has received 3 replies and been viewed 788 times.
post #1 of 4 (permalink) Old 11-08-2009, 06:31 PM Thread Starter
member
Jarods gerbils's Avatar
Need new brakes for the excursion, not going to pay that much at the dealer, what kind of rotors have others used to replace them? Can you get good ones at local auto parts stores, and is it an easy job to replace them? I just want something comparible to factory.......
2006 F-350 6.0 crew cab long bed with line x.
2" leveling in front with 315/65/18 BFG's.
Billet grill
MBRP 4" duals, AFE stage 1, Tunes from Eric @ Innovative and DJ's.
Overhead pod with Isspro guages
Jarods gerbils is offline
post #2 of 4 (permalink) Old 11-08-2009, 07:44 PM
Your best bet is to get some heavy duty rotors or performance rotor from your local parts store if they have it or one of the vendors on this site
joush is offline
post #3 of 4 (permalink) Old 11-09-2009, 02:02 AM
I be Architect'n
I like the Wagner series that o'reilly's sells. They come with a lifetime replacement, if they warp or wearout, just take them in and walkout with new ones.
2K3 EXCURSION 7.3L 4x4 EDDIE BAUER 107K miles as of 06-13-07
AFE Stage II / 4" MBRP exhaust / DP-Tuner F5 (Stock, 60hp Tow, 80hp Econo, 120hp race & High Idle) / Quadzilla Commander/ATS Housing
Running homebrewed BioDiesel and custom SVO kit for 70k miles.:Thumbup:
Misc. Mods: ZooDad/By-Pass Oil Filter/203* T-Stat/Coolant Filter/HPX/CCV Reroute/Tranny Filter/Foil Delete/Stereo Stuff/ITP Reg Return/Non-EBPV Pedistal and Exhaust Housing/Adjustable Waste Gate Controller/
"If you love your motorcycle, set it free. If it comes back to you it was probably a high-side."
I'LL TRY TO KEEP UP, BUT THE EXCURSION IS A BIG GIRL AND BIG GIRLS DON'T LIKE TO MOVE FAST.
6_Myles is offline
post #4 of 4 (permalink) Old 11-16-2009, 10:40 PM
I like my powerslot/hawk severe duty combo. After about 35k I am still at half life on the pads, and they are wearing perfect. Now I am going to have to replace on rotor because of a bad caliper, but it wasn't the failure of the pad or rotor.
early '99 converted to late '99 F-350 dually, 4x4, 4 door, long bed, 6 speed. Midwest transmissions 05+ zf-6 transmission with their short throw shifter and SB clutch. Rosewood 180cc with 80% nozzles, Termy modded 17* HPOP, International bellowed up pipes, fs-2500, DP Tunes. A few other things here and there...
dually club member.. Why replace 5 tires when you can replace seven? I like my training wheels...
calebgriffin31 is offline
PAC Brake Exh. Brake 7.3 99-03 Diesel Diesel Dave 04 Ford Parts 3 08-25-2009 12:17 PM
Rear Brake Replacement 99 F350 brendonv General Ford Truck and Excursion 0 10-18-2007 06:07 PM
rear pad replacement & brake cable how to aldo_45030 1994-2003 7.3L Power Stroke 0 06-04-2007 01:35 PM
Excursion 4cefed 2003-2007 6.0L Power Stroke 12 09-02-2006 07:12 PM
Rotor and brake pad replacement rum4 General Ford Truck and Excursion 9 08-25-2006 01:32 PM
