4WD Troubles - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rduck91, this thread has received 2 replies and been viewed 584 times.
post #1 of 3 (permalink) Old 11-20-2009, 02:33 AM Thread Starter
4WD Troubles
My auto hubs won't engage unless i lock them manually. Checking for vacuum leaks today and found the hub vacuum switch is not switching. Can anyone tell me which wire is witch and what the voltages should be going to this switch?? I checked them and i got 12 volts going there but nothing seems to change when i switch it to 4x4. Thanks Jerry
Jerry
2002 Ford F-250 Crew Cab 4x4, 7.3L P stroke, Auto. Superchips programmer.
Rduck91 is offline
post #2 of 3 (permalink) Old 11-21-2009, 02:04 AM
4play's Avatar
I assume you have a good vacuum supply to the hub/lockout solenoid. the most common problem is the vacuum pump here. The other 2 wires to that solenoid go to the 4wd for module. the module grounds these 2 circuits to activate the solenoid to provide vacuum to the hubs, keep in mind the vacuum to the hubs are pulsed and once engaged the vac supply is cancled because the hubs will maintain engagement/disengagement on their own.
4play is offline
post #3 of 3 (permalink) Old 11-21-2009, 08:30 AM Thread Starter
Thanks 4play,
I do have vacuum to the switch. Pump is good. I checked the switch and it does seem to be grounding the 2 wires when i go to 4x4 but no vacuum is coming out of switch. I am going to get a new switch..
Jerry
Rduck91 is offline
Troubles? rwhite 2003-2007 6.0L Power Stroke 7 02-24-2009 08:45 PM
Troubles with an 01 CTD lbdodge24v 5.9L Cummins (1998.5-2002) 16 12-29-2006 04:39 AM
6.9 troubles 4x4ford 7.3L and 6.9 IDI (Pre 1994) 8 12-24-2006 02:54 AM
car troubles.............HELP!!!!!!!!!!! rubberduckie General Gas Vehicle 4 08-09-2006 02:35 AM
