Ram Air Hood - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by droolinforparts, this thread has received 12 replies and been viewed 1871 times.
post #1 of 13 (permalink) Old 11-23-2009, 03:04 AM Thread Starter
droolinforparts's Avatar
Send a message via AIM to droolinforparts
Ram Air Hood
does anyone make a complete functional (one that doesn't need another part to be bought to make it functional) ram air hood made from metal looking for one for the truck in the sig.
'03 F250 XL 6.0LK&N intake, mbrp 5" stacks, SCT X3 with tunes from innovative, 6" superlift, 315-75r-16,boost, pyro, fuel pressure, oil pressure gauges all in the a-pillar,h-11 studs, short throw shifter,fass 95/150 with complete custom fuel lines, south bend clutch, traction bars
Singles #118
B.O.M.B Squad #28
droolinforparts is offline
post #2 of 13 (permalink) Old 11-24-2009, 06:36 PM
Contain the BTU's...
Wekiwa's Avatar
Sport Truck Direct carries the Reflexion brand of steel hoods. Put one on an 04 last Sept.
Several 04, 05, 06, and a few 07 6.0's
The toy: 05 CC 4x4 SB HD with a few changes.
You only get one chance to provide good customer service the first time. If you do, your customers may tell a few people about you. If you don't, a dissatisfied customer will tell everyone they know and some they dont about you!
Wekiwa is offline
post #3 of 13 (permalink) Old 11-29-2009, 01:28 AM
SLAPS President
teamroper60's Avatar
Images: 9
Considering that the air is drawn into the engine from behind the grille, I don't think you are going to find a truly functional ram air hood (metal or otherwise) that doesn't require some fabrication of parts...
Reflexxion does make one that is metal and vented at the rear. From what I understand with my limited knowledge of such things, going down the road at speed, it should be drawing air into the engine compartment (much like the '70 Trans Am shaker hood did) but it does not connect to the air filter assembly, so that is not a true ram air hood. I have one on my truck and can tell you that at low speeds or idle, it works well to draw hot air out of the engine compartment.
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #4 of 13 (permalink) Old 11-29-2009, 04:51 AM Thread Starter
im not looking for a cowl that draws in the air from the back of the hood im looking for one like this https://www.cervinis.com/product.asp...1&id=1188#1184 (the blue one)
Singles #118
B.O.M.B Squad #28
post #5 of 13 (permalink) Old 11-29-2009, 06:15 AM
SLAPS President
Images: 9
Haven't seen one of those in metal....
#43
post #6 of 13 (permalink) Old 11-29-2009, 01:33 PM
4cstr's Avatar
Images: 35
WOW!!!
they want nearly $600 for the hood...and another $550 for the kit to make it a functional ram air
~Dave~
4cstr is offline
post #7 of 13 (permalink) Old 11-29-2009, 02:53 PM
Why don't you just buy that one? The ram-air hood market for a Super Duty is pretty thin and it's not as if you're swimming in options...
jvencius is offline
post #8 of 13 (permalink) Old 11-29-2009, 02:55 PM
balz out's Avatar
seems like your better off making your own hood... try and find a sd in a junk yard get the hood for like a hundred bucks do some releif cuts and fab up some pieces to weld in and have a body shop touch it up and throw some paint on for you. just my 2 cents
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #9 of 13 (permalink) Old 11-29-2009, 04:11 PM
International350's Avatar
This is what i am looking to do in the near future, cheaper in the long run cause we use body an paint shops at work so they will do it for the cost of paint for me.
2004 F-350 CC LB King Ranch. Under the Hood SCT w/Innovative street tunes by Eric, Hot FICM tuned by Power Hungary, custom built 4" intake with huge afe filter, Intake elbow, 3"down pipe to 5" straight piped stack, EGR block off, Zoodad Mod, CCV mod, Complete EGR delete, The Big 3 cable upgrade w/ batts under cab, Autometer pillar guages, Boost, Trans, EGT. APR studs sitting in box ready for install
Suspension 2.5inch leveling kit. Stock King Ranch 18" rims with 33inch Nitto A/T.
Truck is now pushing 134K miles an running strong.
International350 is offline
post #10 of 13 (permalink) Old 11-29-2009, 11:00 PM Thread Starter
i would rather not buy a fiberglass because after a while it will end up deforming and might rattle
Singles #118
B.O.M.B Squad #28
new hood available... 2008fx4 2008-2010 6.4L Power Stroke 6 11-09-2007 09:35 PM
Under hood pic superf350 2003-2007 6.0L Power Stroke 24 11-26-2006 02:32 PM
New Hood SpicyJam Dodge Performance Forum 7 04-26-2006 10:53 AM
Whose 747 under the Hood? Rick65 Video Discussion & Support 1 04-23-2006 11:51 PM
New Hood umcgrad 2003-2007 6.0L Power Stroke 5 03-21-2006 08:00 PM
