95 f-150 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by vcassens, this thread has received 4 replies and been viewed 450 times.
post #1 of 5 (permalink) Old 11-23-2009, 03:31 AM Thread Starter
vcassens's Avatar
95 f-150
Hey guys and gals I have a 95 F-150 I only have one key for it and I lost it I am wondering if ther is any way that ford can cut a key from the VIN number or do I have to pay out the azz and have a lock smith come to my house and make a key thanks for any and all the help
2004 ford F350 6.0L 6 speed manual,SCT live wire,south bend double disk clutch,short throw shifter fx4. Costome exhaust 4 inch turbo back to 5" homade stacks, banjo bolt mod, shimed regulator,custom leveling kit (not blocks) and air lift air bags with onbord air suply TRADED FOR
2006 ford F 250 Amarillo 4" turbo back other than that stock for now
singles club #206
bomb squad #67
Ridin' Dirty Club #65
vcassens is offline
post #2 of 5 (permalink) Old 11-23-2009, 05:36 AM
4play's Avatar
Ford only started logging the keycut by vin numbers in '99 but It seems to me that they are starting to drop the info after 10years, so the 99's are being phased out or already gone off their logs, and next year the 2000's will go.
If by chance you kept the keycode or original owner did you may be in luck. The keycode would have been on a little tag that came with the original keys, either a metal tag or white plastic tag with a 4-5 digit sequence (cant remember which) Every now and then i have been lucky to find that someone threw this tag into the glove box.
If you have multiple locksmiths in the area I would call around because I have seen a wide variety of pricing for this service. May also be cheaper on you to take the truck to them ( save $$$ on service call )
4play is offline
vcassens (11-23-2009)
post #3 of 5 (permalink) Old 11-23-2009, 03:08 PM Thread Starter
vcassens's Avatar
thanks I called today and they said that they can only go back 10 years so I have to call a lock smith and I cant take it to them because I cant start it with out a key
singles club #206
bomb squad #67
vcassens is offline
post #4 of 5 (permalink) Old 11-23-2009, 10:59 PM
UpstateDieselGuy's Avatar
Can they do anything if you remove the lock cylinder and take it to them? Chris
SOLD
UpstateDieselGuy is offline
post #5 of 5 (permalink) Old 11-24-2009, 01:48 AM Thread Starter
vcassens's Avatar
no they said that a lock smith wold have to do it and me and the wife just moved in to a house and the neighbor across the street is a lock smith so he just walked over with his tool box and made the key and made me a second copy for 35 bucks every wher else that I called was 80 to 150 bucks so I say I came out ahead except the wife the whole week and then some more when I had to pay for the key but all is well and now comes the makeup
singles club #206
bomb squad #67
vcassens is offline
