Heater problems - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Fast_and_furious, this thread has received 1 replies and been viewed 1122 times.
post #1 of 2 (permalink) Old 11-23-2009, 08:06 PM Thread Starter
Heater problems
When at idle me heat will blow cold but when i bring up the rpms or drive it my heat blows hot? Whats going on?
Thanks
03 f-350 cclb srw Oilguard bypass filter sct (doug and spartans tunes) boost,trans,pyro only problems 1 injector and a couple of reflashes runs flawless (knock on wood)
New Toy 97 dodge 2500 4x4 12 valve 4in turbo back exhaust and stock plate FF for now.
Mods to come in the near future
Built Trans, DV, 4k gsk, injectors??, studs
Fast_and_furious is offline
post #2 of 2 (permalink) Old 11-30-2009, 06:15 AM
same thing happened to me, add coolant and it should fix your problem.
EJ Krueger is offline
The Following User Says Thank You to EJ Krueger For this addition to TDG:
Fast_and_furious (11-30-2009)
heater jdreda Duramax 2001-2004 (LB7) 1 11-03-2009 01:04 AM
heater problems deere puller General Ford Truck and Excursion 5 02-28-2008 09:16 PM
Block Heater Installation Problems DIESELDUCK2 2003-2007 6.0L Power Stroke 1 01-20-2008 12:27 AM
No Heater? worktruck General Ford Truck and Excursion 1 11-02-2006 02:14 AM
Electrical problems/dash problems curtis2003 5.9L Cummins (2003-2007.5) 1 10-21-2006 08:27 AM
