thinking of regearing for towing - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cycojon, this thread has received 5 replies and been viewed 1139 times.
post #1 of 6 (permalink) Old 11-24-2009, 02:37 PM Thread Starter
dezert addict
so i have an 04 F-250 with 35's and stock 3.73's
I have read alot, searched alot, seems a 4.30 gear would get me a little lower than stock. my question is, if im towing a 5th wheel that is regularly 12,000 lbs and in the future maybe near 15,000lbs would i benifit more to jump to a 4.56 instead of the 4.30? I do not plan on running larger tires than the 35's. Im just wondering if i will get more bang for my buck running 4.56's or if that would be too low.
thanks
cycojon is offline
post #2 of 6 (permalink) Old 11-24-2009, 06:30 PM
Contain the BTU's...
Wekiwa's Avatar
thanks
The Tow Boss option uses 4:30's. With your 35 in tires, your cruising speed will drop a little, but will help over all mileage. We haul 18K+ regularly with our fleet and the 4:30's work great.
Something to consider; in order to maintain the magic 2K rpm limit, higher gear ratios (more torque) like 4:56 will reduce cruising speed when unloaded.
Wekiwa
Several 04, 05, 06, and a few 07 6.0's
The toy: 05 CC 4x4 SB HD with a few changes.
You only get one chance to provide good customer service the first time. If you do, your customers may tell a few people about you. If you don't, a dissatisfied customer will tell everyone they know and some they dont about you!
Wekiwa is offline
post #3 of 6 (permalink) Old 11-26-2009, 01:51 PM
harry6.0's Avatar
The towboss with 4:30's drives nice with stock dually wheels, as a friend of mine has that model. Being that your running 35's I would recommend 4:56 ratio gears. Were talking basically changing your driveshaft from turning 1/2 a turn(4:30) to 3/4 a turn(4:56) more for every turn of the wheels. Being you'll be towing fairly heavy, you will want those lower gears especially on hills. Your truck will pull noticably better all around with the 4:56's and 35's. Harry
harry6.0 is offline
post #4 of 6 (permalink) Old 11-26-2009, 02:32 PM
Images: 2
Ok I will jump on this wagon also. I have a travel trailer and will more than likely get a toyhauler soon. I have a 4.5 inch lift and 35's on the truck. I drive it unload more than I tow. Should I go 4.11's? I tow the trailers about 5 or 6 times a year.
2006 PSD 4X4
lilgsx is offline
post #5 of 6 (permalink) Old 11-27-2009, 04:35 AM
harry6.0's Avatar
Heres a site that gives a calculation that may help. Go to the second one down and enter your original tire size and current new larger tire size then your current diff ratio. When you enter the tire sizes put (31.6) or (35), and when you enter your diff ratio just put (3.73) or (4.10) etc.
http://www.4lo.com/4LoCalc.htm
Harry
harry6.0 is offline
lilgsx (11-27-2009)
post #6 of 6 (permalink) Old 11-29-2009, 01:38 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
cycojon: I would go with the 4.30s in your situation I believe..
lilgsx: I would def. go w/ the 4.10s in your situation. I run 4.30s and have both 35s and 37s... The 4.30s and 35s work great pulling the camper but I hate running empty with the setup. It puts my rpms higher than I like for just running around. Since you dont pull very often I would do the 4.10s
2003 F250 "Pulling Truck"
hhrecovery is offline
The Following User Says Thank You to hhrecovery For this addition to TDG:
lilgsx (11-29-2009)
Thinking About A LMM hccumminssmoke Duramax 07.5-2010 (LMM) 18 07-03-2009 05:21 AM
What was I thinking??? Chobeeman The Parking Lot 19 02-06-2008 03:21 AM
37s need regearing for the 6.7l? torturekilla General Dodge Discussion 6 11-07-2007 05:07 AM
