2003-2007 recon mirror gap - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by utlonghorns416, this thread has received 4 replies and been viewed 658 times.
post #1 of 5 (permalink) Old 12-07-2009, 10:40 AM Thread Starter
utlonghorns416's Avatar
Images: 1
I installed some recon clear mirror lights and the passenger side is good but the driver side has a bad gap at the bottom. Any body else have this problem, if so how did you fix it ?
Please post pics of gap before and after if you will.
Thx for your help !
R.I.P Lewis Lamb (lambstroker6.o) Feb 13th 2010
"Life is all about the ride 513"
utlonghorns416 is offline
post #2 of 5 (permalink) Old 12-09-2009, 02:26 PM
Pursuit Interceptor
HeavyAssault's Avatar
Images: 5
I have stayed away from that particular Recon product when I saw first hand the poor QA of the fit.
I have used their cab light kit for over 3 years with no issues.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #3 of 5 (permalink) Old 12-09-2009, 11:23 PM Thread Starter
Images: 1
I seen good and bad fitments. I have their cab lights too and like the look with the white trucks.
post #4 of 5 (permalink) Old 12-10-2009, 09:36 PM
9 STECK
One Fast Harley's Avatar
I have Recon smoked mirror, roof, and third brake lights. I do know what you are talking about with the mirror lights, as I had the same problem. I do not have any pictures to show, but what I did was cut out 4, 2 for each side, little U shaped clips from stainless steel shim stock. They are about 3/4" "square" with a slot cut from one side. With the mirror lights installed, I slipped these U shaped clips under the plastic clips that are on the lights that are suposed to hold them in. This pulled the lights down a little tighter and now they look factory. No gaps whatsoever. I was a little displeased with the original fit, but with this little garage engineering they fit perfect. Hope this helps.
OFH
2011 F350 CC SB Lariat Tuxedo Black with black leather
5er/goose prep, 3.55 e-locker, Navi with premium sound.
Recon smoked mirror lights, smoked Atomic LED roof clearance lights, Recon Big Rig Ice lights on custom stainless pinch weld covers, Limo Tint, Hide-away-strobes, 50 gallon titan fuel tank, Zone off road 2" leveling kit (not high enough), two more factory fogs in between tow hooks, factory fogs as reverse lights in custom mounts under rear, spray in bed liner in the bed and on the factory step bars, more to come...
TRADED 02/11-2005 Harley Davidson F350 CC SB #348
One Fast Harley is offline
post #5 of 5 (permalink) Old 12-11-2009, 12:16 AM Thread Starter
Images: 1
Thanks I give that a try.
installing recon mirror lts PKeel 08 6.4l 2008-2010 Body & Suspension 4 08-25-2009 10:49 AM
Recon Mirror LED Lights fordt Whats Been Sold 5 12-30-2008 02:58 PM
Recon LED Mirror Lights HotSauce2138 Whats Been Sold 6 01-29-2008 11:45 AM
Recon Mirror Lights For 03-07 Superduty's HotSauce2138 Whats Been Sold 3 01-04-2008 01:49 AM
Putco vs Recon Mirror lights Squatch General Ford Truck and Excursion 3 11-04-2007 11:23 PM
