Brake problems.. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by NorwegianFord, this thread has received 9 replies and been viewed 1542 times.
post #1 of 10 (permalink) Old 12-09-2009, 02:03 PM Thread Starter
Brake problems..
started smoking from the right back wheel yesterday.. we started taking the breaks apart, found some burned "gaskets"(pressing the pads) but we want to take eveything apart to make sure there isn't more problems.. but didn't get much further than what the pictures show..
how do we get the disk of?? Haynes says "pull it right out..", but it's stuck, stuck, stuck.. what are we doing wrong?
sorry about the lousy pics..
Rik
ID:	23597   Click image for larger version
NorwegianFord is offline
post #2 of 10 (permalink) Old 12-09-2009, 02:09 PM
7.3 addict
use a large hammer to knock it loose hit it in the area where the rust is on the drum area in 4places till it starts to free up at the studs DONT hit it where the pads ride
1) 99 f-350 srw 7.3 6pos. bully dog, afe intake, mrbp 4" exhaust,250,000 miles and still rollin.
2) 2000 excursion 7.3 afe intake, mrbp 4" exhaust. chip coming
3) NEW TO ME2000 cc drw 7.3 let the mods begin
4) FOR SALE 87 f250 6.9 9' utility body.
5) SOLD 91 f150 good truck just well used.Gonna miss the old girl allways started even after sitting for 6 months.
I think i'm trailer poor ) 22' w\18' tilt car hauler, 18' flat bed, 2 horse D&D, 12' utility, 19' "v" nose, and 37' 5er
"quote from tank"
"I use baby wipes.....
Because if you think that a wadded up piece of paper is actually getting the chit off of your butt.....then I have to ask a question....
.....if you wiped a turd on your arm....would you just use a paper towel to get the turd off?.....or would you wash your arm?...
...let that thought roll around in your head for a moment...
" thank you tank for that insightful thought
#46 AMERICAN (blood) club
#241 singles club
# ? Dually club
# ? Excursion club
jestersv is offline
The Following User Says Thank You to jestersv For this addition to TDG:
NorwegianFord (12-09-2009)
post #3 of 10 (permalink) Old 12-09-2009, 02:26 PM
Mod Friendly Title
Zaairman's Avatar
Hit the brake rotor 10x inbetween each wheel stud. It'll pop off. Some PB Blaster wouldn't hurt either.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
The Following User Says Thank You to Zaairman For this addition to TDG:
post #4 of 10 (permalink) Old 12-09-2009, 05:55 PM Thread Starter
ok! thanks! we'll keep on hitting it!
post #5 of 10 (permalink) Old 12-11-2009, 07:50 AM Thread Starter
Yes! A larger hammer and more violence did it! It's off!
post #6 of 10 (permalink) Old 12-18-2009, 06:09 AM
Drill and tap 2 holes between opposite studs and thread a bolt in to press the rotor off. Drill just through the rotor but not the hub, grind a drill to bottom and use a bottoming tap or grind a little thread off the starting end of the bolt.
Same with hub centered wheels. Add a 5/16 threaded hole for bolts to remove the wheels when you forget the no-seize.
keydl
81 Isuzu /C223na, 5spd
keydl is offline
post #7 of 10 (permalink) Old 12-18-2009, 11:58 AM
Bigking's Avatar
Get some lube and a good mallet.
05' F-250, Harley Davidson #2993, True Blue
SCT X2 programmer (innovative tuned), MBRP 4in turbo back SS Cool Duals, Gutted Cat, S&B cold air intake, 2" front 1" rear lift, 325x60x20 Nitto Terra Grapplers, Stock Harley 20" rims, Line X, 20% tint all around, Alpine Linear Sub system, 4k Sylvania Silver Star lights, Zoo Dad mod, line of fire by Recon, ARP head studs, RCD EGR delete, new heads, new Turbo, dual bilstein steering stabilizers, bilstein 5100 shocks all 4 corners, truxedo bed cover, Amsoil. U.S.C.G
Bigking is offline
post #8 of 10 (permalink) Old 12-19-2009, 01:39 PM
harry6.0's Avatar
Make sure to change the rubber flex hoses on both rear calipers or all 4 calipers, as this is the no.1 cause of most calipers sticking closed. The internal cavity of the rubber hoses can deteriorate and become restrictive. Very common and often overlooked, as I have seen many times where people have changed the calipers and or master cylinder only to have the same thing happen because they didn't change the hoses. Harry
harry6.0 is offline
post #9 of 10 (permalink) Old 05-28-2010, 11:16 AM Thread Starter
Thanks!
post #10 of 10 (permalink) Old 05-28-2010, 12:36 PM
brendonv's Avatar
Dually? You need to remove those 8 bolts for the axle shafts!!!
Early 1999 F350 DRW Dump, 6spd 4x4, 4" Turbo Back and DIY Intake
Early 1999 F350 SRW 8' Box, 6spd 4x4 Stock
brendonv is offline
brake problems GubNi 1994-2003 7.3L Power Stroke 1 06-06-2009 01:11 PM
Possible brake problems??... HawaiianSuperDuty General Ford Truck and Excursion 6 01-31-2008 04:45 PM
brake problems smokndiesel7588 7.3L and 6.9 IDI (Pre 1994) 3 11-26-2007 04:37 PM
Brake problems drsam 1994-2003 7.3L Power Stroke 6 06-23-2007 10:05 PM
Brake problems drsam 1994-2003 7.3L Power Stroke 0 06-22-2007 10:33 PM
