factory lift blocks? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by strokin 6.0, this thread has received 12 replies and been viewed 1532 times.
post #1 of 13 (permalink) Old 12-19-2009, 07:52 PM Thread Starter
diesel power!!
strokin 6.0's Avatar
does any one know if the 04 f250 fx4 has factory rear lift blocks and what size they are? sorry for the dumb question im not by my truck right now and was looking at a cheap way to lift it for now. thanks
2004 f250 6.0 psd, 285/75r16 pro comp x terrains, 5 inch suspension lift, 5 inch exhaust from the down pipe back, k&n intake, hyper tech, full egr delete and arp head studs for now
strokin 6.0 is offline
post #2 of 13 (permalink) Old 12-19-2009, 09:51 PM
Good on gas, hell on dzl
DZL HOG's Avatar
It should have 2" blocks just like any other 250. 350s have about a 4" block from the factory.
2006 F250 Super Duty Harley Edition #00604
Black with blue flames Crew Cab, long bed.
MBRP 4" Duals, AEM intake, Accufab elbow, SCT tuned by DJ(Looney)and Spartan, DJs Fuel + Intensifier, Dieselsite coolant filter, Commander monitor for gauges, PML front diff cover, cheap locker in front, Icon leveling kit, Icon Dual steering stabs, OneUpOffroad front link arms, OUO 5" traction blocks, Bed Rug, Pace Edwards Bedlocker.
DZL HOG is offline
post #3 of 13 (permalink) Old 12-19-2009, 10:11 PM
I Wanna Go Fast!
brentos's Avatar
They are 2.5 for 250s and 3.75 for the 350s
brentos is offline
post #4 of 13 (permalink) Old 12-20-2009, 04:13 AM
StrokerDude's Avatar
Actually they are 2 for 250's From my experience with my 06 F250 and many others I've been under.
And 3.75 for F350 from my experience with my 99 F350 and many others I have been under.
Alex C.
StrokerDude is offline
post #5 of 13 (permalink) Old 12-21-2009, 02:21 PM Thread Starter
diesel power!!
sweet thanks i was looking at summit racing and they have these 5.5 inch lift block for the rear i was going to do that and then get new leaf packs for the front which they say comes to a 4 inch lift for the front then it would be somewhere around a total of 3 in the back i shouldn't have any problems with the drive shafts anything right? thanks in advance
post #6 of 13 (permalink) Old 12-21-2009, 04:16 PM
lilpooh's Avatar
IDK what cab configuration you have, but if you have a carrier bearing on the drive shaft, you might have to shim it.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #7 of 13 (permalink) Old 12-21-2009, 05:40 PM
if you do not have a carrier bearing then you need to get your blocks with the proper angle on them in order to set your pinion angle right.
On edit, looking at your avatar it looks like you have a crew cab shortbed, so you should have a carrier bearing. Shim the carrier bearing properly, but still pay attention to the angling of the blocks you buy BEFORE you buy them.
Alex C.
post #8 of 13 (permalink) Old 12-22-2009, 03:36 PM Thread Starter
diesel power!!
its the 4 door and yes it does have a carrier bearing what do you look for in the angle of the blocks? sorry for the dumb questions but much appreciated!
post #9 of 13 (permalink) Old 12-22-2009, 07:41 PM
lilpooh's Avatar
Try this link, and scroll down to the skyjacker kits. They show a 2" block drop, $48 #CBL 206. Then contact one of the vendors to see if they can hook you up.
http://www.rockymountainsusp.com/fd4_05f2_350.htm
lilpooh is offline
post #10 of 13 (permalink) Old 12-26-2009, 08:09 PM Thread Starter
diesel power!!
thats awsome thanks!
wtb: factory 4" (F-350) rear blocks dondiesel444 Ford Parts wanted 2 11-12-2009 06:56 PM
Crushed lift blocks fordt The Parking Lot 28 07-21-2009 06:47 AM
Lots of Lift Blocks justinlw Whats Been Sold 11 05-26-2009 12:23 AM
F/S Lift Blocks justinlw Whats Been Sold 4 04-14-2008 03:32 AM
