flasher relay for leds - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by nick0360, this thread has received 7 replies and been viewed 1195 times.
post #1 of 8 (permalink) Old 12-22-2009, 09:52 PM Thread Starter
nick0360's Avatar
any one know where i can get a flasher relay to slow down my directionals. since I put recon leds in the headlight they blink fast because they draw less power. I know recon has them but was looing for something more local like a napa or something any one corrected this problem?
2003 F-350 SC SB 6.0 Powerstroke 4X4, k&n intake, 4in turbo back stainless into 6in miter stacks, sct xcal 3 innovative, cale, elite, autometer phantoms II (trans,boost,pryo), full suncoast w/deep mag-tec, gillette diesel egr cooler delete, cfm large mouth intake elbow, coolant filter, ARP studs, zoozad mod, ccv mod, ITP RR, swamps ficm upgrade, 6k HID head and fog, '06 front end w/harley lights, '08 tailgate and taillights, 20x9 kmc XD hoss 305/50/20 toyo proxes STII, 20% tint , clear rencons all around and thats about it for now
nick0360 is offline
post #2 of 8 (permalink) Old 12-23-2009, 12:32 PM Thread Starter
nick0360's Avatar
or a load resistor thats what there called
nick0360 is offline
post #3 of 8 (permalink) Old 12-24-2009, 01:05 PM Thread Starter
nick0360's Avatar
thanks for the help guys
nick0360 is offline
post #4 of 8 (permalink) Old 12-27-2009, 05:07 AM
I know at work the pick-up techs swap out a flasher relay in the fuse panel under the steering wheel I believe. They use a motorcraft packaged relay I think but not sure. I am also a tech in the same shop but only work on the semi's so I don't have first hand experience with this issue on the superduty's. If I remember, I can ask one of the guys for the part #. Maybe you can cross it to a napa # for half the price.
'06 F-250 CC SB, lifted 10.5 Rize Industries, 38" Nitto Muds on 20" Moto Metal 951, Bilstien 7100 reservoirs, Fabtech Dirt Logic 2.0 Steer stabs with Rize bracketry, MBRP 4" turbo back cool duals- no muff or kitty, CCV mod, coolant filter kit made by me, rest of 6.0 stock for now.
4xtim is offline
post #5 of 8 (permalink) Old 12-27-2009, 01:05 PM
go to a local truck shop and ask if they have a HOBBS variable load flasher, if they dont they should be able to get them and this will solve your problem
05EXCURSION is offline
post #6 of 8 (permalink) Old 12-27-2009, 04:56 PM
UpstateDieselGuy's Avatar
Any electronic flasher should do. Chris
SOLD
UpstateDieselGuy is offline
post #7 of 8 (permalink) Old 12-28-2009, 03:12 AM
Haulin' Hay
NCfarmboy's Avatar
Pretty sure it's an EP-27 flasher -- can be bought at Advance Auto, NAPA, etc. It's under the steering wheel - a 2 minute swap, and will fix your problem. Easiest way to find it is turn on your turn signal, and listen for the ticking under the dash
NCfarmboy is offline
post #8 of 8 (permalink) Old 12-31-2009, 12:57 AM Thread Starter
nick0360's Avatar
thanks guys got a load resistor from a local custom truck shop
nick0360 is offline
Help Flasher dougs03 General Ford Truck and Excursion 5 04-15-2008 06:51 PM
noise help. I think its the flasher. shownlow 2003-2007 6.0L Power Stroke 2 01-13-2008 08:09 PM
GOT LEDs????? BeauxPete General Ford Truck and Excursion 11 10-26-2007 11:09 AM
flasher/indicator relay Mad Dog Cycles General Dodge Discussion 2 04-05-2007 10:25 PM
The Flasher StuckinMud The Parking Lot 4 10-24-2006 12:39 PM
