07 Hit deer, need bumper solutions, OEM or Aftermarket - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by GM Guy, this thread has received 10 replies and been viewed 1819 times.
post #1 of 11 (permalink) Old 01-03-2010, 03:06 AM Thread Starter
Man. Trans 2wd Enthusiast
I have a broke cowboy buddy that needs to fix his truck back up for cheap.
He has a 2007 F250 PSD CCSB auto 4wd, and i was riding with him when we nailed a doe, luckily it hit dead center, so the only damage is the a/c condenser, bumper, foglights, and plastic strip above the bumper. amazingly the grille was spared.
He is a fellow near-broke college student like me, so he nneds to spend as little as possible to get it back right.
I am sure the condenser will wait till warm weather, so right now it is the bumper and related components.
The problem is the truck is a bright red XLT, so that means there is a fairly uncommon filler strip out there, as it seems not many folks get bright red around here.
So my questions are: roughly how much will a plastic strip run new? if it is too much, he and i are thinking he needs to buy a custom fit heavy bumper.
If we do go that route, what is the best bang for the buck (brand) in aftermarket bumpers?
also, what do OEM takeoff bumpers usually run?
99 Chev C3500 6.5L NV4500 14 bolt 2wd 4.10 130K White Ext, Gray Int. RC159.5" WB DRW Chassis Cab with utility box Runs Great, building up
96 GMC C2500HD 6.5L NV4500 14 bolt 2wd 3.73 240K White Ext, Blue Int. ECLB 155.5"WB SRW Pickup runs bad, getting motor right now
95 GMC C2500HD 6.5L NV4500 14 bolt 2wd 4.10 135K White Ext, Grey Int. RC 131.5"WB SRW Pickup with utility box runs strong, yet huffs on 1 hole
95 Chev C3500HD 6.5L NV4500 D80 2wd 5.13 132K White Ext, Grey Int. RC 159.5"WB DRW Chassis Cab with flatbed bad heads, needs motor re-do
94 GMC C2500HD 6.5L 4L80E 14 bolt 2wd 3.73 300K White Ext, Blue Int. Suburban needs engine
91 GMC C1500, 6.2L SM465 10 bolt 2wd 3.42 59K Red Ext, Red Int. RCLB 131.5"WB SRW Pickup needs injectors, oil cooler lines
91 Chev C1500 4.3L 5LM60 10 bolt 2wd 3.42 ??K White Ext, Red Int. RCLB 131.5"WB SRW Pickup needs...alot
Dad's:
98 GMC C3500 5.7L Vortec NV4500 208K down right now, needs head gaskets (dex cool claims another set! )
92 GMC C3500HD 6.5L Turbo NV4500 160K needs exhaust system and oil cooler lines
93 GMC C3500HD 6.5L Turbo 4L80E 260K had a crate 6.5L sometime
All above are 159.5" C&C, 10'-12' flatbed, Summit white, RC, SL trim, 2wd
96 GMC C2500HD SL ECLB 6.5L 5spd 2wd. 215K (sold to dad, ran good for a bit, started missing at idle, had blowby since purchase
84 Pete 362 COE, 300 BCIII RTOO 13 spd Fuller (3 OD ratios, hard to find) Single axle tractor, air seats, cab, suspension, OEM twin 200 gallon tanks.
74 Pete 352 COE, cat, 13spd TS, B&H grain truck
90 Marmon 57P long hood conventional, 60"flattop, 12.7L60 Series, 13 spd fuller, TS tractor
76 Marmon COE 8V92T 13spd fuller, TS B&H grain truck
95 IHC 9600 COE M11, 10 spd, SA tractor.
GM Guy is offline
post #2 of 11 (permalink) Old 01-03-2010, 03:12 AM
fine69's Avatar
You can look up Factory parts here, they have Good prices too.
www.powerstrokeshop.com
H-M.W.H. Club #2
Union Club #1
Singles #237
B.O.M.B. Squad #12
Ridin' Dirty Club #17
American Club #15
fine69 is offline
The Following User Says Thank You to fine69 For this addition to TDG:
GM Guy (01-03-2010)
post #3 of 11 (permalink) Old 01-03-2010, 03:30 AM Thread Starter
thanks, ill look into it!
Dad's:
GM Guy is offline
post #4 of 11 (permalink) Old 01-03-2010, 11:23 AM
Saftman's Avatar
Where are you located?
Saftman is offline
post #5 of 11 (permalink) Old 01-03-2010, 12:39 PM
bushpilot's Avatar
try LMCTruck - http://www.lmctruck.com/icatalog/fe/t.aspx
Don R.
Truck Audio,
bushpilot is offline
post #6 of 11 (permalink) Old 01-04-2010, 04:25 AM Thread Starter
i forgot about lmc, thanks! He has to go to leavenworth for some army stuff, so i think he can even go pick it up, maybe save some $ that way.
Thanks again!
Dad's:
GM Guy is offline
post #7 of 11 (permalink) Old 01-04-2010, 04:49 PM
99_stroker's Avatar
after u said cowboy the only thing that came to mind was a ranchhand thats what i got and im happy
Grein,
1999, ford f-250 superduty cc, lb, diy intake, dp tuner, 3 gauge pillar, tint all the way around, gto smoked heads and tails, uniden cb, recon smoked cab lights, recon running lights, recon third brake light
99_stroker is offline
post #8 of 11 (permalink) Old 01-05-2010, 05:30 AM Thread Starter
thats exactly what he needs, but he cant afford it, he spends too much on beer.
Dad's:
GM Guy is offline
post #9 of 11 (permalink) Old 01-05-2010, 04:44 PM
99_stroker's Avatar
i totally understand
Grein,
post #10 of 11 (permalink) Old 01-06-2010, 01:35 AM
vcassens's Avatar
I am looking at bosshog bumpers they are a little cheaper than ranch hand and built about the same also he got lucky my uncle hit one with his 05 and had to replace the bumper,grill,left head light,left fender,hood,and every thing behinde the grill including the fan so if he can drive the truck my advice wold be to drive it until he can get an aftermarket one to protect his truck from the deer
http://www.bumpersandbeds.com/Boss_H...lacements.html
2004 ford F350 6.0L 6 speed manual,SCT live wire,south bend double disk clutch,short throw shifter fx4. Costome exhaust 4 inch turbo back to 5" homade stacks, banjo bolt mod, shimed regulator,custom leveling kit (not blocks) and air lift air bags with onbord air suply TRADED FOR
2006 ford F 250 Amarillo 4" turbo back other than that stock for now
singles club #206
bomb squad #67
Ridin' Dirty Club #65
vcassens is offline
New aftermarket bumper available!!!! sprman General Parts and Accessories 1 01-20-2009 12:59 PM
WAIT!...New Aftermarket Bumper Option. TANK'S 250 The Parking Lot 51 12-27-2008 01:38 AM
Aftermarket Dodge bumper....pic TANK'S 250 The Parking Lot 38 12-26-2008 12:57 AM
Deer oh deer. lots of snow.... danster The Parking Lot 4 03-17-2008 07:04 PM
