4wheel drive help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by littlebigrig6.0, this thread has received 12 replies and been viewed 854 times.
post #1 of 13 (permalink) Old 01-05-2010, 03:13 AM Thread Starter
little big rig 6.0
Exclamation 4wheel drive help
I was out plowing with the truck the other day, when I noticed my front tire, I believe its only the right front, sounds as if I have a rubber flap hitting the tire. This is only when in 4 wheel drive, not sure about 4 low. When I take it out of 4 it stops making this noise. any ideas on what this could be.
6.0l, bully dog triple pup, dual 5"bull hauler stacks, strait pipe from turbo back
littlebigrig6.0 is offline
post #2 of 13 (permalink) Old 01-05-2010, 03:17 AM Thread Starter
little big rig 6.0
woops sory wrong spot, can someone move this thread
post #3 of 13 (permalink) Old 01-05-2010, 03:49 AM
Im having this same problem any help plz
jordan_labelle is offline
post #4 of 13 (permalink) Old 01-05-2010, 04:59 AM
Have you checked the steering knuckle u-joint, the lock-out hub, or the ball joints?? I would remove the tire/wheel and start there...
Fast_Ashley is offline
post #5 of 13 (permalink) Old 01-05-2010, 04:26 PM Thread Starter
little big rig 6.0
locking hubs were replaced as well as ball joints, hope its not the u joint that must be a big job
post #6 of 13 (permalink) Old 01-06-2010, 07:06 PM Thread Starter
little big rig 6.0
no one else has any idea what would cause this,
post #7 of 13 (permalink) Old 01-06-2010, 09:27 PM
BillsFan's Avatar
Jack it up and spin the tire(s), see if you can track down the source of the noise. Push, pull, poke everything in there until you find something loose or broken.
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
post #8 of 13 (permalink) Old 01-06-2010, 10:37 PM
Have you taken the wheel off and done any visual or physical inspection of the suspected area?? Process of elimination actually works...
post #9 of 13 (permalink) Old 01-06-2010, 11:14 PM Thread Starter
little big rig 6.0
I did today, and the only thing I found was the black plastic ring was loose, I have the picture in another post, spun the wheel, rocked it shook it did everything I could think of and nothing, I may jack the whole truck up and basically drive it on blocks, also checked the diff fluid, the front dif is black and smells weird, also the fluid was a little low
post #10 of 13 (permalink) Old 01-06-2010, 11:19 PM
********* and Mafia #90
Bcarriveau's Avatar
only real way to check ball joints it so jack the tire up just enuf to get a large pry bar under it and pry up on the tire while someone watches the balljoints very closely for movement.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
4wheel drive problems bisket 2003-2007 6.0L Power Stroke 2 02-17-2008 08:15 PM
4Wheel drive not working cdiesel 1994-2003 7.3L Power Stroke 7 01-01-2008 04:07 PM
For those that wonder what I drive... 2003EDGE General Gas Vehicle 8 10-01-2006 05:46 PM
Drive like Granny=OK, Drive like Earnhardt=stalls at idle GeneralLeo 1994-2003 7.3L Power Stroke 3 09-15-2006 03:39 AM
I get to drive... 4cstr The Parking Lot 11 05-17-2006 03:13 PM
