Black rubber/plastic ring where front axle pics included - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by littlebigrig6.0, this thread has received 13 replies and been viewed 987 times.
post #1 of 14 (permalink) Old 01-06-2010, 05:31 PM Thread Starter
little big rig 6.0
Exclamation Black rubber/plastic ring where front axle pics included
I was looking at my hub today and noticed a black rubber or plastic ring there the u joint meets the axle, either way what is this ring its loose on both sides pass and drivers also u joint seems a little loose. Im going to take a pic
6.0l, bully dog triple pup, dual 5"bull hauler stacks, strait pipe from turbo back
littlebigrig6.0 is offline
post #2 of 14 (permalink) Old 01-06-2010, 05:54 PM Thread Starter
little big rig 6.0
the yellow is the ring that is very loose
Name:	Western Joy Stick 001.jpg
post #3 of 14 (permalink) Old 01-06-2010, 06:47 PM
bushpilot's Avatar
this LOOKS like the vacuum seal & hub o-ring.
the oring should NOT be loose...my bet is youre also having a problem w/ the ESOF
hub engagement (either the hub WONT lock, or if it does, it likely will not UNLOCK).
dont know your mileage or age, but while youre there you probably should plan
on replacing the balljoints while you have it apart to fix the seals.
these pictures and write ups will be helpful -
http://www.guzzle7pt3.com/allube.php
http://www.google.com/search?q=super...nt+replacement
Don R.
Truck Audio,
bushpilot is offline
post #4 of 14 (permalink) Old 01-06-2010, 06:48 PM
Curmudgeon
TooManyToys's Avatar
Very loose and very normal. It's a dirt shield that IMO is there more for looks.
Don - that's the axle side, not the hub side.
Jack -
Formerly FMTRVT, Manager of Vehicle Testing - Brakes
2003 F-350SC Lariat 4x4 6.0L Auto
Truck Modifications as below in Pictorials on Facebook. Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
TooManyToys is offline
post #5 of 14 (permalink) Old 01-06-2010, 06:52 PM
bushpilot's Avatar
if its the PUMPKIN side then the <BLACK> dust shield is normally LOOSE...and
as jack says, its a JOKE.
the yellow o-ring should NOT be loose...it should be inside the HUB...
Don R.
Truck Audio,
post #6 of 14 (permalink) Old 01-06-2010, 07:05 PM Thread Starter
little big rig 6.0
ok cause I was wondering if this is the thumping noise coming from the front when my 4 hi is engaged
post #7 of 14 (permalink) Old 01-06-2010, 07:05 PM Thread Starter
little big rig 6.0
oh and ball joints were done already
post #8 of 14 (permalink) Old 01-06-2010, 10:39 PM
That black rubber seal is virtually useless...
Fast_Ashley is offline
post #9 of 14 (permalink) Old 01-06-2010, 10:49 PM
bushpilot's Avatar
ok, my bad, i thought the your yellow line was the yellow o-ring/seal.
the dust seal is loose, as it should be.
check your sway-bar drop links to make sure theyre not "blown"
Don R.
Truck Audio,
post #10 of 14 (permalink) Old 01-06-2010, 10:53 PM
********* and Mafia #90
Bcarriveau's Avatar
I got mine into place and silicone'ed it to the axle or axle saft, what ever one it fit better on, cant recall
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
front drive lineline will spin but wont lock into front axle Wally1tm 5.9L Cummins 12 Valve (1994-1998.5) 3 12-13-2009 07:33 PM
Which Wheels Look The Best? Pics Included ! Still Strokin The Polling Place 12 02-24-2009 12:09 AM
WTB..... Rubber that goes on the front bumper of OBS GilroyRacing Whats Been Sold 2 08-04-2007 01:42 AM
Shock installed finally...PICS INCLUDED! 1SD General Ford Truck and Excursion 34 01-16-2007 01:26 AM
front axle snap ring / ball joint replacement nichols 1994-2003 7.3L Power Stroke 3 09-21-2006 02:56 PM
