08 mirrors? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bootcamp, this thread has received 5 replies and been viewed 836 times.
post #1 of 6 (permalink) Old 01-07-2010, 10:19 AM Thread Starter
bootcamp's Avatar
08 mirrors?
Who has the old style mirrors on there truck with the new 08 mirrors. and where did you get them and did the wiring match up.
TIA Paul
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline
post #2 of 6 (permalink) Old 01-07-2010, 03:04 PM
6speed7.3's Avatar
I have a 2000 with 08 mirrors on it. Love it. So much easier to pull with. but it's a pain in the butt to install them. Darrell at dppp put my mirrors in. Wired it up perfect.
No the wires don't line up. 08 mirrors have 7 wires and the stock mirrors have three.
6speed7.3 is offline
post #3 of 6 (permalink) Old 01-07-2010, 07:16 PM
What do the 05+ models have? Do they interchange better on them?
05 F-250 CC SB,Torqshift, 5" ProComp, 20x10 Fuel Hostage, 35" Federal Couragia M/T, B&W ball, MBRP 5" turbo-back, SCT X3, Edge Insight w/pillar mount, Truxedo roll cover*****SOLD***
KYmxracer52 is offline
post #4 of 6 (permalink) Old 01-09-2010, 02:17 PM Thread Starter
bootcamp's Avatar
does any body have a web site that I can look at them and order some?
USMC 87-90 MOTOR-T
bootcamp is offline
post #5 of 6 (permalink) Old 01-10-2010, 04:31 PM
Big Stroker
Keanoknick's Avatar
Send a message via MSN to Keanoknick
On mine the wires matched up, 3 for adjusting the mirror, 2 for turn signal, and 2 for heat. However moving the mirror it acts wierd, if you push L, the mirror will go Down and Left at the same time, Right will go up and Right at the same time, UP and Down work normal. It makes it a little harder to get them where you want them, but it's not a big deal to me.
2005 F250 CC SB FX4
8" lift; 38.5" Procomps; ARP Headstuds; Banks Intercooler and High Ram Elbow; 4" Exhaust; SCT with custom tunes by Tony Wildman; Isspro Performax guages; '08 TT mirrors; Bushwacker Pocket Style Flares; Recon somked cab and mirror lights; Frontier front bumper replacement; AMP Research power runnning boards; Fabtech floating traction bars
North Texas Powerstroke Association www.NTxPSA.com
Riding High Club #3
Ridin' Dirty Club #10
American Club #39
Keanoknick is offline
post #6 of 6 (permalink) Old 01-10-2010, 04:46 PM
bushpilot's Avatar
99-07 mirrors are interchangeable
folks w/ the smaller PADDLE mirrors have OFTEN switched 'em for
the larger TOWING MIRRORS.
around 02 ford added the LED's for marker lights & turnsignals...IIRC
by 04 they added HEAT (always on) to the LARGER portion of the TOW mirror.
you can buy <relatively> inexpective 99-07 Tow mirrors from LMC TRUCK (image below)
if you want 08 TOW mirrors on your 99-07 truck you can buy 'em from a sponsor
of this site dfuser...be prepared to lay out a 1400 for the electrically folding version,
or 800 for the MANUAL fold mirrors !
http://www.dfuser.com/catalog/2008-f...7-f250f450.php
Don R.
Truck Audio,
bushpilot is offline
Will 09 TT mirrors swap with 04 paddle mirrors WasGas General Ford Truck and Excursion 5 11-20-2009 01:29 AM
96 Tow Mirrors Burner718 1994-2003 7.3L Power Stroke 3 01-06-2008 01:13 PM
3rd Gen Mirrors hccumminssmoke 5.9L Cummins (1998.5-2002) 21 12-26-2007 03:41 PM
Mirrors tbroadus_41 5.9L Cummins (1998.5-2002) 14 11-30-2007 01:57 AM
Anybody using these mirrors? Firestorm The Parking Lot 3 03-11-2007 04:05 AM
