lights - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by PowerstrokePower55, this thread has received 2 replies and been viewed 695 times.
post #1 of 3 (permalink) Old 01-08-2010, 06:53 AM Thread Starter
PowerstrokePower55's Avatar
lights
guys my headlights will only come one when u turn the switch all the way to the left (on auto or whatever) if u turn it to the right in the parking light position nothing comes on and if u turn it to the headlights position the headlights come on with no parking lights no tailights and no other lights(dash, cab, or mirror) anyone got any advice
2006 F350, 6.0L powerstoke diesel,SCT SF3 Custom tunes, AFE cold air intake,swamps upgraded FICM, ARP studs, Black Onyx Gaskets, EGR Deleted, cooper discoverer S/T 35" tires, AFE 5inch straight pipe. Garret Powermax, 190cc sticks, Airdog 2. 'MERICA
PowerstrokePower55 is offline
post #2 of 3 (permalink) Old 01-09-2010, 05:23 AM
********* and Mafia #90
Bcarriveau's Avatar
My guess is the plug on the back of it is loose or the switch is bad. Im leaning to the switch being bad. Try and find someone to swap with to verify.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #3 of 3 (permalink) Old 01-10-2010, 04:00 PM
Do your turn signals and break lights work normally? Keep your lights off, then activate your LH turn signal. Get out of your truck and look to see that your LH turn signal is blinking (don't rely on what you hear and see on your dash).
There's a junction box (I've heard) in 6.4L trucks that affect the control of your lights. I'm not sure if it's in the 6.0L, but I'd start with finding out whether or not your turn signals and brake lights work normally without your headlights.
BTW - It's highly unlikely that it's a switch problem especially since *all* of your lights don't work in that position. I'd start looking elsewhere. Also, did you add any electrical things to your truck? Additional lights? Radio? CB? Fuel tank? Air compressor? Reason I ask is because you probably ought to check your work to make sure that nothing was damaged in the process of that installation.
timid1 is offline
running lights for fog lights bcmueller 5.9L Cummins (1998.5-2002) 4 01-01-2008 12:21 AM
fog lights on w/parking lights Strokin05 General Ford Truck and Excursion 10 10-15-2007 12:07 AM
no park lights or dash lights Super Limo 1994-2003 7.3L Power Stroke 2 02-09-2007 11:34 AM
1997 f-350 clear cab lights, and runnins lights STROKETHIS7.3 1994-2003 7.3L Power Stroke 1 12-22-2006 12:40 AM
fog lights, head lights & brights fordfanatic69 2003-2007 6.0L Power Stroke 5 06-04-2006 03:58 AM
