door key code pad - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by vcassens, this thread has received 11 replies and been viewed 1965 times.
post #1 of 12 (permalink) Old 01-08-2010, 06:44 PM Thread Starter
vcassens's Avatar
door key code pad
My key pad on my door quit working it wont light up and nothing happens when I push the numbers any sugestions thanks
2004 ford F350 6.0L 6 speed manual,SCT live wire,south bend double disk clutch,short throw shifter fx4. Costome exhaust 4 inch turbo back to 5" homade stacks, banjo bolt mod, shimed regulator,custom leveling kit (not blocks) and air lift air bags with onbord air suply TRADED FOR
2006 ford F 250 Amarillo 4" turbo back other than that stock for now
singles club #206
bomb squad #67
Ridin' Dirty Club #65
vcassens is offline
post #2 of 12 (permalink) Old 01-08-2010, 07:23 PM
AmarilloSD's Avatar
was it an addon (stick on) unit? if its not hardwired my guess is the battery is dead, we add the keyless pads all the time and they are basically a keyless remote with a combo
2006 f350 C.C.SB Amarillo Edition- Afe Stage 2 intake, SCT, mbrp 5" turbo back with 6" tip, 7" icon lift,325/50/22 dynapro atms on 22x11 black XD diesels, keystone heat extractor hood, 4.30 gears, 03 turbo DR/icon traction bars, Hd Heads, Painted front and rear bumpers, arp head studs, Welded EGR
wish list/coming soon-banks ic, regulated return fuel system, Tuned FICM, but not if i do a CR cummins first!
AmarilloSD is offline
post #3 of 12 (permalink) Old 01-08-2010, 08:44 PM
nick0360's Avatar
where do you get the stick on ones are they easy to install like program to the truck?
2003 F-350 SC SB 6.0 Powerstroke 4X4, k&n intake, 4in turbo back stainless into 6in miter stacks, sct xcal 3 innovative, cale, elite, autometer phantoms II (trans,boost,pryo), full suncoast w/deep mag-tec, gillette diesel egr cooler delete, cfm large mouth intake elbow, coolant filter, ARP studs, zoozad mod, ccv mod, ITP RR, swamps ficm upgrade, 6k HID head and fog, '06 front end w/harley lights, '08 tailgate and taillights, 20x9 kmc XD hoss 305/50/20 toyo proxes STII, 20% tint , clear rencons all around and thats about it for now
nick0360 is offline
post #4 of 12 (permalink) Old 01-09-2010, 04:58 AM Thread Starter
vcassens's Avatar
no it is factory and I can use the keyless remote and start the truck every thing works fine just not the combo pad
singles club #206
bomb squad #67
vcassens is offline
post #5 of 12 (permalink) Old 01-09-2010, 05:07 AM
********* and Mafia #90
Bcarriveau's Avatar
is it flush with the door or is it about a 1/2 thick?
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #6 of 12 (permalink) Old 01-09-2010, 05:09 AM Thread Starter
vcassens's Avatar
flush with the door
singles club #206
bomb squad #67
vcassens is offline
post #7 of 12 (permalink) Old 01-09-2010, 05:21 AM
Bcarriveau's Avatar
flush with the door
Check all fuses(19,102,17,7), it might even be a bad VSM(vehicle security module).
Da Rules..Here
Dear Tequila:
The TDG TOTQ
The Following User Says Thank You to Bcarriveau For this addition to TDG:
vcassens (01-09-2010)
post #8 of 12 (permalink) Old 01-09-2010, 03:02 PM
fordsuperduty01's Avatar
Probably a bad keypad. I replaced mine last year as it would light up but only one of the buttons worked. It was around $50 from ford. Might want to pull the door panel and see if it is just a connection issue.
2005 F-250 6.0L King Ranch FX4. 125k miles, Edge Platinum, EGR delete, MBRP turbo back exhaust without cat, an 03 turbo, and 4.30 gears.
A.S.E. Master certified automotive and light duty diesel technician.
fordsuperduty01 is offline
The Following User Says Thank You to fordsuperduty01 For this addition to TDG:
vcassens (01-10-2010)
post #9 of 12 (permalink) Old 01-10-2010, 12:44 AM Thread Starter
vcassens's Avatar
thanks for the advice when it warms up I will look into it more and maybe find out what is wrong with it and thanks again. If ther are any more ideas pleas share and I will start a check list of things todo
singles club #206
bomb squad #67
vcassens is offline
post #10 of 12 (permalink) Old 01-12-2010, 04:56 PM
AmarilloSD's Avatar
stick ons can be purchased from the dealer, they are super easy to program takes 5 mins to install
Can I Put J-Code Exhaust Manifolds On a C-Code Engine JLanzino 6.2L Diesel Engine 6 10-08-2009 02:29 AM
'Door Ajar' lamp staying on w/ door closed??? BlownGreenGP General Ford Truck and Excursion 4 02-03-2008 04:22 AM
Door/seatbelt dinger and door seal mod...awesome... John_DeereGreen 1994-2003 7.3L Power Stroke 18 12-24-2007 09:15 PM
How to find door keypad code..... aald4x4 General Ford Truck and Excursion 4 10-15-2006 06:03 PM
Garage Door Opener Compartment Door iwejan Whats Been Sold 2 05-04-2006 12:09 PM
