Freezing! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by drsam, this thread has received 6 replies and been viewed 792 times.
post #1 of 7 (permalink) Old 01-13-2010, 12:49 AM Thread Starter
Freezing!
Okay guys its too cold to feed my cattle every morning with the passenger side window stuck down!!!!!! Its been acting up for a few weeks, sometimes wouldnt come up on first try, but would later, but yesterday put it down and that was it! Wont come up with either switch. Figured it was the motor and got a new one, hooked it up before putting back in and nothing! Guy from NAPA tells me if the drivers side switch is out then neither will work. Is this correct? What can I do to figure this out! Its a 2001 F250.
drsam is offline
post #2 of 7 (permalink) Old 01-13-2010, 01:14 AM
Mod Friendly Title
Zaairman's Avatar
Sounds like its your switch.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #3 of 7 (permalink) Old 01-13-2010, 02:16 AM Thread Starter
But which one? Neither will work. Is it true that if the drivers side switch is bad the passengers won't work either?
drsam is offline
post #4 of 7 (permalink) Old 01-13-2010, 02:39 AM
Mod Friendly Title
Zaairman's Avatar
Yes...
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
The Following User Says Thank You to Zaairman For this addition to TDG:
drsam (01-13-2010)
post #5 of 7 (permalink) Old 01-13-2010, 03:33 AM
plainredtruck's Avatar
Images: 11
Um, pull the stinkin' inside door cover off and put that freakin' window up!!!
Zaairman has good info. I'd vote for the switch as well.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #6 of 7 (permalink) Old 01-13-2010, 08:07 AM
Unplug the window motor and with a jumper to the motor run it up. With a wiring diagram you can use a short jumper on the drivers side switch.
Or change the drivers side switch - it is less than a trip to the dealer.
The jumper wire to the connector at the top of the door is simple - I cut a short extension cord and put battery clips on one part and use another extension cord to get power from the nearest avail, what I am working on or my pickup.
81 Isuzu /C223na, 5spd
keydl is offline
post #7 of 7 (permalink) Old 01-13-2010, 04:59 PM
99_stroker's Avatar
anyone think there could be a gremlin in there somewhere were water of something may have got into the wiring harness in the door?
Grein,
1999, ford f-250 superduty cc, lb, diy intake, dp tuner, 3 gauge pillar, tint all the way around, gto smoked heads and tails, uniden cb, recon smoked cab lights, recon running lights, recon third brake light
99_stroker is offline
Its Freezing.............. danster The Parking Lot 32 01-17-2009 03:50 PM
Fuel Freezing Big Gray dodge 5.9L Cummins 12 Valve (1994-1998.5) 17 01-05-2008 10:15 PM
05 6.0L in freezing temps MaverickUF 2003-2007 6.0L Power Stroke 32 01-30-2007 02:32 PM
Freezing Rain !! BROKER The Parking Lot 11 01-31-2006 07:38 PM
No Freezing Water If Moving Right? bigdraft The Parking Lot 21 11-18-2005 11:15 PM
