spray on liner on running boards? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Russ, this thread has received 2 replies and been viewed 601 times.
post #1 of 3 (permalink) Old 01-21-2010, 10:23 PM Thread Starter
Found On Russ' Drive
Russ's Avatar
The paint keeps peeling off of my running boards(smooth aluminum), and I was thinking about using some off the shelf spray/roll on liner material on them. What are your thoughts on how well it would hold up, and how slippery would it be when wet? Thanks.
Duct tape... turning No No No into mmmmmm mmmmmmm mmmmmmm
Stormtrooper::1997 F-350 CC SRW PSD XLT 4X4: 332 hp 660 tq. made with Baby Swamps, Wildman 4 pos chip, 120V IDM, CCV mod, shimmed FPR, BTS E4OD, Baldwin air filter,triple pillar pod with Isspro gauges, 4" MBRP exhaust, SD dual tensioner mod, diamond cut headlights,Recon LED tailgate lights Hadley air horns,
Russ is offline
post #2 of 3 (permalink) Old 01-22-2010, 02:06 PM
TDG Mafia Member#67
6L strokin's Avatar
ive had friends that used to DIY bed liner with some success... ive never had much luck with it.. looks good for a while but then starts chipping/flaking. i'd say you need to prep it really well. maybe even run by a shop that does spray in bedliner and get a quote from them if you took them off and dropped off at their place.... might be cheap enough to justify not screwing with it.
another option would be the rubberized undercoating and it holds up really well but it needs plenty time to set up or it will stick to your shoes!
Previous Rides:
1997 F150 EC SB 4x2 xlt red
6L strokin is offline
post #3 of 3 (permalink) Old 01-23-2010, 01:04 PM
TxFireman1972's Avatar
I would say take them somewhere and have them done. I just had a tool box done. Did the entire box for $100. Just tell them you're not in a hurry and they can wait till they are doing a bedliner in a truck or something. That way they dont have to do a special job just for you. It will last alot longer than the rattle can stuff.
2005 F350 Crew Cab 4x4
PMF Rear Leaf Spring Conversion w/2011 Leaf Springs
20" Harley Wheels 305/55/20 Nitto Terra Grapplers
ARP Studs & EGR Delete from PowerStrokeMagic w/GearHead Tunes
Amp Research Steps, MBRP
TxFireman1972 is offline
99+ CC running boards 6L strokin Whats Been Sold 3 03-01-2009 02:13 PM
spray in bed liner POWER STROKE 99 General Ford Truck and Excursion 8 06-22-2007 04:19 PM
Running boards Summit6.6 Whats Been Sold 6 10-05-2006 06:45 PM
OEM Running Boards 01duramax6spd Whats Been Sold 4 09-10-2006 03:25 AM
Check out this 'new' spray-in bed liner idea TooMuchBoost The Parking Lot 7 10-19-2005 12:07 PM
