When rear brakes go bad. pics - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 04lariatfx4crewcab, this thread has received 21 replies and been viewed 2727 times.
post #1 of 22 (permalink) Old 01-26-2010, 02:02 AM Thread Starter
04lariatfx4crewcab's Avatar
OK I set out to fix those sqweeling brakes. I take off the passenger rear tire and this is what I see.
Not too bad looks like there is a bit of life left on them.
Then I notice this.
now that looks a bit odd.
That should not be that thin. I could not find my brake shoe on the piston side of the caliper.
I wish I had a picture of the caliper but here is what is left of one of the pistons.
so after $130.00 trip to Advanced Auto to get a new caliper and rotor I proceed to finish the job when I found that my caliper bracket was messed up. One of the brake caliper bolts does not slide it is welded in place. So after 8 hours beating on this to get it out with a 3lb sledge I gave up and ordered a new bracket.
oh I did find my inside brake pad it was lodged between the rotor and the dust shield. it looks a bit thin too.
The onl thig I can gather is that the guy I bought the truck from did a brake jobe but when he was puting it back together the inside pad fell off and he did not notice.
Jakob
2004 5.9L/47rh Lariat FX4 Crew Cab Short bed. 213K miles 18" dbacks with nitto A/T grapplers, Zoodad mod, and 2000 turn signal mod. Limited Excursion bumpers front and back. Chrome grill, EGR delete, FICM delete, glow plug delete, HPOP delete, 2 cylinders delete, and 20 valves deleted
97 12v/47rh built by Garmon's
04lariatfx4crewcab is offline
post #2 of 22 (permalink) Old 01-26-2010, 02:06 AM
I Wanna Go Fast!
brentos's Avatar
wow that is by far the worst worn rotor i have ever seen
brentos is offline
post #3 of 22 (permalink) Old 01-26-2010, 12:12 PM
Curmudgeon
TooManyToys's Avatar
Originally Posted by 04lariatfx4crewcab View Post
.......The only thing I can gather is that the guy I bought the truck from did a brake job but when he was putting it back together the inside pad fell off and he did not notice.
Nope. The caliper pin rusting into the bracket is what caused this. It kept the brake pad against the rotor's inner surface so both the pad and rotor wore down. Eventually the friction material is worn away and the steelback gets it's turn to wear against the rotor. Once it gets thin enough it is ejected out of the bracket and then the pistons get their turn to run the gauntlet. The stainless steel caps on the piston don't take too long to wear away and soon your down to phenolic plastic piston itself.
While I don't have much presence over here, on TDS I've spent years advising to check all four brakes every one to two years to insure that all of the pins are sliding freely, the slide pin boots are in good shape on retained on the mounting lips, and the brake pads move freely in the brackets. It's a fair amount of work but with this vehicle brake design, it's the only way to prevent expensive repairs.
It's also best to do the brake check when you buy a used vehicle. If I were you, I'd be checking the other brakes as well. Although many times it's just one bad apple.
Jack -
Formerly FMTRVT, Manager of Vehicle Testing - Brakes
2003 F-350SC Lariat 4x4 6.0L Auto
Truck Modifications as below in Pictorials on Facebook. Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
TooManyToys is offline
post #4 of 22 (permalink) Old 01-26-2010, 12:32 PM
bushpilot's Avatar
occasional tire rotation would have prevented that...and this ->
Don R.
Truck Audio,
bushpilot is offline
post #5 of 22 (permalink) Old 01-26-2010, 12:48 PM
TEXAS FIGHT
Hellraiser's Avatar
@ least you got if fixed
08 F250 Ext. Cab LWB 4x4.
Hellraiser is offline
post #6 of 22 (permalink) Old 01-26-2010, 02:35 PM
69cj's Avatar
100% agree. 5,000 mile tire rotations and a quick check when doing it should prevent this. Remember; maint, maint, maint!
69cj is offline
post #7 of 22 (permalink) Old 01-26-2010, 02:39 PM
Administrator
fordt's Avatar
Images: 5
WOW. That is pretty bad. I do not have the pictures handy, but I had a '97 F350 that the front were so bad it was starting to grab the "fins" because the rotors had wore down to nothing.
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
post #8 of 22 (permalink) Old 01-26-2010, 02:49 PM
bushpilot's Avatar
the old adage "pay me now or pay me later" certainly applies here !
doesnt matter WHAT pads you buy...theyre cheaper than rotors, calipers and pads.
this is an EASY DIY job, no reason to pay 100s to someone when you can DIY.
theyre PRETTY when new too....
Don R.
Truck Audio,
post #9 of 22 (permalink) Old 01-26-2010, 10:15 PM
********* and Mafia #90
Bcarriveau's Avatar
Worst i ever let mine get..
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #10 of 22 (permalink) Old 01-26-2010, 10:19 PM
69cj's Avatar
Billy, That right one looks like you were on borrowed time.
69cj is offline
Rear Brakes Don J 1994-2003 7.3L Power Stroke 6 04-07-2009 08:28 PM
rear brakes ccp Whats Been Sold 1 03-28-2007 08:18 PM
rear brakes ccp 1994-2003 7.3L Power Stroke 11 03-28-2007 02:48 AM
More brakes in rear? Horsehaulin Medium and Heavy Duty 4 02-20-2007 02:15 AM
Rear Brakes jpeters448 Duramax 2001-2004 (LB7) 5 05-01-2006 06:20 AM
