cable abjustment on back seat lowering lever - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by yamaman, this thread has received 1 replies and been viewed 429 times.
post #1 of 2 (permalink) Old 01-31-2010, 06:46 PM Thread Starter
Hey everyone just seeing if there is a way to adjust the cable for the back seat for the lever that lets the back of the seat drop down flat? Somehow the cable lossened off on me. I have the seat torn apart and don't see how it could have loosened off. Maybe is there suppose to be a spacer of some kind between the cable stop and the lever? Anyone have some insight? Thanks alot
yamaman is offline
post #2 of 2 (permalink) Old 02-02-2010, 03:43 PM Thread Starter
got it figured out for those of you who may have this problem here is the fix
So What happened to mine was the bracket that holds the cable slide to go the the other side of the seat had bent and the cable slide slipped off so when you would pull the lever only the drivers side of the seat would unlock and not let you lower it. All I had to do was open up the drivers side on the seat and bend the bracket back up and slip the slide back into place and bam it was fixed.
So lesson learned don't let you wife try to lower the back seat if it doesn't move she puts it all into it and bends steel!!
yamaman is offline
Back Seat Subs circle5 The Parking Lot 8 08-23-2007 01:19 AM
CrewCab Back Seat fuzzys69 General Ford Truck and Excursion 10 02-09-2007 05:06 AM
Back Seat Heaters Sader123 General Ford Truck and Excursion 3 02-08-2007 11:19 PM
Back seat frame for an 05 heinzboy Whats Been Sold 0 05-01-2006 02:08 AM
XCal 1 computer cable back ordered? nummit 2003-2007 6.0L Power Stroke 9 08-31-2005 01:56 PM
