How to wire for heated seats in an XLT? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dougger222, this thread has received 4 replies and been viewed 3062 times.
post #1 of 5 (permalink) Old 02-02-2010, 02:52 PM Thread Starter
Installed newer Lariat front seats in the 99 F250 XLT and my mechanic and I are stumped as to go about wiring for heat. The original seats were not power but we were able to get power to the driver seat and that works.
Is there anybody here that would know how to go about the install? If there's a way to hardwire and for it to work we are open for that option as well as the factory set up. Guessing if we went factory we'd either need to buy new or try to find a junk yard donor?
We were able to get the seat belts figured out which was very easy. Of course there's holes in the headliner from the old seat belt mounts but my mechanic filled them with plastic plugs.
The newer style seats are way nicer than the original style seats.
Now just to get some heat in them for the cold Minnesota Winters!
Thanks for any help!!!
Doug
00 Excursion 7.3 4x4 Limited (wifes)
99 F350 7.3 4x4 Lariat crew cab DRW
99 F250 7.3 4x4 xlt x-cab
00 BMW 328CI 2dr silver fully loaded (wifes)
69 GTO 400 4spd
65 Mustang 289 (wifes)
04 and 09 15yrd PJ dump trailers
04 H&H 20ft tilt bed trailer
98 7x14 Haulmark trailer
dougger222 is offline
post #2 of 5 (permalink) Old 02-02-2010, 07:38 PM
brendonv's Avatar
I can't help but maybe you can help ME. Where did you get the power for the driver side seat?
Early 1999 F350 DRW Dump, 6spd 4x4, 4" Turbo Back and DIY Intake
Early 1999 F350 SRW 8' Box, 6spd 4x4 Stock
brendonv is offline
post #3 of 5 (permalink) Old 02-03-2010, 12:11 AM Thread Starter
I'm not totaly sure I'll ask my mechanic and post back. Guessing he ran a positive lead off the fuse panel but could be wrong.
The Following User Says Thank You to dougger222 For this addition to TDG:
brendonv (02-03-2010)
post #4 of 5 (permalink) Old 02-03-2010, 12:33 AM
brendonv's Avatar
I'd appreciate it.
brendonv is offline
post #5 of 5 (permalink) Old 02-03-2010, 04:25 PM
check underneath the carpet. I know in my 03 xlt i have a connection for heated seats. I also have the connection for the pedals to move that i found when i put my high idle switch in. wont hurt to look.
03 f-350 cclb srw Oilguard bypass filter sct (doug and spartans tunes) boost,trans,pyro only problems 1 injector and a couple of reflashes runs flawless (knock on wood)
New Toy 97 dodge 2500 4x4 12 valve 4in turbo back exhaust and stock plate FF for now.
Mods to come in the near future
Built Trans, DV, 4k gsk, injectors??, studs
Fast_and_furious is offline
Heated Seats Not under ESP WARRANTY??!! cattech05 2008-2010 Body & Suspension 4 01-19-2010 12:45 AM
Heated seats axe man 2003-2007 6.0L Power Stroke 1 12-31-2009 05:47 PM
heated seats jdreda Duramax 2001-2004 (LB7) 4 01-28-2009 02:52 AM
Heated seats??? MRBOHN23 General Ford Truck and Excursion 3 12-12-2007 08:24 AM
Heated seats Wiring Smokem 5.9L Cummins (1998.5-2002) 8 11-15-2007 05:31 PM
