95 headlight switch nob fell off - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DEERE3594, this thread has received 7 replies and been viewed 1441 times.
post #1 of 8 (permalink) Old 02-05-2010, 03:22 PM Thread Starter
Penguin
DEERE3594's Avatar
My buddy has a 95 f350, the headlight switch nob came off and we cant figure what holds it on. Any ideas?
-Justin
1994 Chevrolet K3500 CCLB dually 6.5 (mine)
1997 Chevrolet C3500 CCLB dually 6.5 (wifes)
Couple other GM's,some trailers, tractors, and about a half dozen horses...
Dually Club member #67
DEERE3594 is offline
post #2 of 8 (permalink) Old 02-05-2010, 06:24 PM
4play's Avatar
If just the knob came off, there is a metal clip that should go into the knob. That clip is what holds it on the switch stem. this clip is also what you need to release to properly remove the knob through the groove on the end of the knob. Its possible the clip is broken/missing, or still on the switch stem.
4play is offline
DEERE3594 (02-10-2010)
post #3 of 8 (permalink) Old 02-06-2010, 03:30 PM
Big Stroker PSD's Avatar
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Big Stroker PSD is offline
The Following User Says Thank You to Big Stroker PSD For this addition to TDG:
post #4 of 8 (permalink) Old 02-06-2010, 08:26 PM Thread Starter
Penguin
DEERE3594's Avatar
thanks guys! if i were to go to a junk yard to get one off how would i do that with out braking it?
-Justin
post #5 of 8 (permalink) Old 02-07-2010, 01:11 AM
I think you can take a small screwdriver and push the clip in on the back of the nob and it sould come off .
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
post #6 of 8 (permalink) Old 02-07-2010, 02:21 AM
4play's Avatar
what BSP said, just pull the knob out ( headlamps on ) then turn the knob and find the notch at the base of the knob and slide a small screw driver ( pocket sized works good ) or a pic, into the notch. you should feel some slight spring tension, when you have the screwdriver positioned into the notch the knob just pull off rather easily.
4play is offline
post #7 of 8 (permalink) Old 02-10-2010, 03:46 PM Thread Starter
Penguin
DEERE3594's Avatar
Thank you all for the help!
-Justin
post #8 of 8 (permalink) Old 02-10-2010, 10:13 PM
sounds like you got er fixed !
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Headlight switch Farmrod Dodge parts wanted 0 09-17-2009 01:51 AM
Hub Fell Off! fordt Towing and Hauling 18 08-10-2009 12:58 PM
Headlight switch issue TLadd 5.9L Cummins 12 Valve (1994-1998.5) 7 05-24-2009 02:29 PM
diesel fell 1.5 superdave The Parking Lot 9 11-21-2007 11:00 PM
muffler fell off Chillinthemost 2003-2007 6.0L Power Stroke 2 04-12-2007 02:45 PM
