Shifter problems!!!??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by S04X, this thread has received 5 replies and been viewed 1251 times.
post #1 of 6 (permalink) Old 02-06-2010, 11:09 PM Thread Starter
Exclamation Shifter problems!!!???
Need some help.[/B] I backed out of the driveway and when I shifted to Drive it would not pull. Shifted back to reverse and it moved, back to Drive and it moved but it now goes forward in any shifter position except park. Park holds and comes out just like normal. The shifter indicator moves like it's working but it's not. No grinding or scrubbing noises. Eased back into the driveway. Any thoughts or ideas appreciated. I have not made any close examinations yet. My shop is my gravel driveway, it has rained the last couple of days, it's 30 degrees outside and it's dark. I will check it over tomorrow but thought I would ask in case anyone can tell me what to look for. First thought was to post this in the 6.0 forum, but decided to try here first.
Thanks
S04X
2004.5 Excursion EB, 195,555 mi., 4X4 6.0L w,auto trans. MBRP 4" exhaust turbo back lost kitty, AFE Stage 2 intake,ARP head studs, RCD EGR delete, SCT w/ Looney, old Edge to read EGT and Boost only, AirDog II HFCM delete ,
S04X is offline
post #2 of 6 (permalink) Old 02-07-2010, 01:08 AM
Big Stroker PSD's Avatar
check the plastic clip on the end of the linkage at the trans. somtimes they work loose
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Big Stroker PSD is offline
post #3 of 6 (permalink) Old 02-07-2010, 02:50 AM Thread Starter
Thanks. I'll let you know what I find.
S04X is offline
post #4 of 6 (permalink) Old 02-07-2010, 03:31 AM
StrokerDude's Avatar
doubtful that it's that because it is still going into park.
Alex C.
StrokerDude is offline
post #5 of 6 (permalink) Old 02-07-2010, 02:09 PM Thread Starter
Bad news. The problem is not outside the transmission unless it is electrical. All the fasteners and clips are in place. Move the shift lever and it moves the cable which moves the rod going into the transmission just like it should. So I guess it is inside the transmission and the next step is pull the transmission pan and take a look. If anyone has a diagram or bottom view picture of the guts, please let me know. I will keep you posted.
S04X is offline
post #6 of 6 (permalink) Old 02-07-2010, 11:28 PM Thread Starter
Update
Scanned the Excursion. No engine DTC, No Transmission DTC. Body codes U1058, U1059, U1073, U1262, U1027 and B1352. I know the codes short definition. What I don't understand is what to do about them or if they have any connection to my tranmission problems.
S04X is offline
Shifter knob bannon_500 2003-2007 6.0L Power Stroke 1 12-09-2009 02:35 AM
92-96 4X4 shifter Diesel Dave 04 Ford Parts wanted 0 10-27-2009 12:52 AM
Manual 4 X 4 shifter Hellbilly 2008-2010 6.4L Power Stroke 17 10-10-2009 03:00 AM
