4X4 not staying engaged - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by littlebigrig6.0, this thread has received 8 replies and been viewed 1164 times.
post #1 of 9 (permalink) Old 02-12-2010, 04:10 AM Thread Starter
little big rig 6.0
My 04 f250 will not stay engaged. Its electric, I know the worst, next truck will be manual 4 wheel. Anyways I was out plowing yesterday and it kept coming in and out of 4H, once I locked my hubs then it would stay engaged. I replaced the 4 wheel solenoid and both locking hubs were replaced about 2 years ago. Also when it is engaged their is a lot of noise, such as the left front tire their is a loud thumping noise, kinda like someone keeps hitting the tire with a mallet, and a lot of whining and vibrating. Also ball joints were replaced the same day the hubs were replaced. Any ideas would be great
6.0l, bully dog triple pup, dual 5"bull hauler stacks, strait pipe from turbo back
littlebigrig6.0 is offline
post #2 of 9 (permalink) Old 02-12-2010, 04:38 AM
4play's Avatar
From the way its sounds, I would start by looking closely at the vacuum lines going down to the hub(s). You might have a line thats cracked or cut. The noise you are hearing is probably the hub engaging/disengaging due to a possible loss of vacuum. If the A/C-heater controls work fine and dont switch to DEF automatically then I would doubt you have a vacuum pump problem but its possible ( elec vac pump is mounted on top of pass inner fender in eng compartment, just forward of the blower motor )
4play is offline
post #3 of 9 (permalink) Old 02-12-2010, 05:15 PM Thread Starter
little big rig 6.0
Before I replaced the vacuum solenoid, my heat would go to def, but now that's fixed, another way to describe the noise is, its like theirs a piece of rubber flap hitting the tire. its only when the 4X4 is engaged.
post #4 of 9 (permalink) Old 02-12-2010, 11:10 PM
Big Stroker PSD's Avatar
could be the vacuum seal in the hubs . I have had trouble with the seals after I changed the ball joints . They are easy to damage .
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Big Stroker PSD is offline
post #5 of 9 (permalink) Old 02-13-2010, 12:01 AM Thread Starter
little big rig 6.0
but what would cause this weird thumping noise
post #6 of 9 (permalink) Old 02-13-2010, 12:30 AM
rock removal technition
sounds like the hub is not staying locked in
double-s-diesel is offline
post #7 of 9 (permalink) Old 02-13-2010, 03:00 PM
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
post #8 of 9 (permalink) Old 02-13-2010, 08:18 PM
4play's Avatar
As said, it sounds like the hub is engaging/dis-engaging. If the noise goes away when you manually lock it then that should pinpoint it. I would be looking for a vacuum leak, low vac supply from pump, seals on the lockout etc...
4play is offline
post #9 of 9 (permalink) Old 02-14-2010, 12:41 AM Thread Starter
little big rig 6.0
No noise gets worse when manually locked, I have to lock them to keep the 4X4 engaged
Cooling Fan staying on/engaged all the time International350 2003-2007 6.0L Power Stroke 10 11-12-2009 01:50 AM
4x4 engaged-rougher turns... 99fordtruckguy 1994-2003 7.3L Power Stroke 8 01-30-2008 12:51 PM
Perma-Grin Engaged Shadowskater 1994-2003 7.3L Chips & Tuners Forum 7 07-20-2007 01:38 PM
04-18-5 Axle - Front Hubs Not Engaging, Not Staying Engaged And/or Unlocking Squatch Ford Oasis requests 0 03-23-2007 11:54 AM
Where is Everyone Staying in Indy? MOMBENZ Events and Gatherings 11 06-15-2006 02:05 PM
