How large of a tire will the stock carrier hold? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by angrywasp, this thread has received 4 replies and been viewed 913 times.
post #1 of 5 (permalink) Old 02-15-2010, 02:12 AM Thread Starter
I know there is a limit to space with the exhaust routed to the back but how much will the stock carrier hold in weight? I'm looking at getting wheels/tires and I don't want a 37 inch tire coming loose under the bed while driving as I think it would cause a small problem. I'm planning on having the exhaust come out in front of the rear wheel if it's safe for the larger tire to mount under the bed. If it's not safe I guess I'll give up some bed space and mount it in the bed. Planning on ProComp Extreme A/T 37x12.5R18 on Extreme Alloys Series 1059 18x9.5.
2005 F250 FX4 6.0L 3.73LS 5R110 - Stock
angrywasp is offline
post #2 of 5 (permalink) Old 02-15-2010, 02:49 AM
Send a message via AIM to gtdan01
Just make sure it is an aluminum rim and you should be okay. I shoved a 35" tire underthe bed in the tire carrier.
2006 F250 6.0 diesel Lariat Fx4
gtdan01 is offline
post #3 of 5 (permalink) Old 02-15-2010, 02:51 AM
Good on gas, hell on dzl
DZL HOG's Avatar
Not sure on the weight, but its not much extra room b/t the factory spare and the back of the hitch.
2006 F250 Super Duty Harley Edition #00604
Black with blue flames Crew Cab, long bed.
MBRP 4" Duals, AEM intake, Accufab elbow, SCT tuned by DJ(Looney)and Spartan, DJs Fuel + Intensifier, Dieselsite coolant filter, Commander monitor for gauges, PML front diff cover, cheap locker in front, Icon leveling kit, Icon Dual steering stabs, OneUpOffroad front link arms, OUO 5" traction blocks, Bed Rug, Pace Edwards Bedlocker.
DZL HOG is offline
post #4 of 5 (permalink) Old 02-16-2010, 02:25 PM
bootcamp's Avatar
I have a 35 mounted under the back. I dont think a 37 will fit, if it does it will be really close.
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline
post #5 of 5 (permalink) Old 02-16-2010, 03:22 PM Thread Starter
Went and measured it. You could squeeze a 36 in between the hitch arms (it would require a spacer to keep it off the hitch mounting bolts) but the 37 won't fit. My main concern was whether it would hold the weight safely but now I guess I'm going to look for a bed mount system.
Spare Tire Carrier Question 99fordtruckguy 1994-2003 7.3L Power Stroke 8 01-08-2008 11:42 AM
how much hp can a stock tranny hold ramdiesel277 5.9L Cummins (2003-2007.5) 7 07-23-2007 08:15 PM
Swing away tire carrier ovruigo General Ford Truck and Excursion 4 08-22-2006 08:26 PM
Stock turbo hold up?? R4farms 5.9L Cummins 12 Valve (1994-1998.5) 3 06-29-2006 02:11 PM
Large Rear Single Tire ? Up-n-Cummins Medium and Heavy Duty 13 01-11-2006 11:53 AM
