How to Remove Fuel Lines from Tank - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by yamaman, this thread has received 7 replies and been viewed 12338 times.
post #1 of 8 (permalink) Old 02-18-2010, 06:30 PM Thread Starter
What do I have to do to remove the fuel lines going to the sending unit on a stock 2006 F350 diesel? Thanks
yamaman is offline
post #2 of 8 (permalink) Old 02-18-2010, 08:18 PM
SSpeeDEMONSS's Avatar
i just had to use a flat head and popped them off i believe.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #3 of 8 (permalink) Old 02-19-2010, 03:14 AM Thread Starter
I got them there is a blue tab on the one and a white tab on the other you have to simply push them in and pull them off, but they are a PITA to get off. I phoned the ford dealer and talked to the tech he said to do this he said to make sure not the wreck them because you have to replace the whole line.
yamaman is offline
post #4 of 8 (permalink) Old 02-19-2010, 03:50 AM
bushpilot's Avatar
its easily done using a tool like these (available at nearly any auto parts store)
http://www.lislecorp.com/tool_detail.cfm?detail=680
Don R.
Truck Audio,
bushpilot is offline
post #5 of 8 (permalink) Old 02-19-2010, 04:03 AM
4play's Avatar
Your fuel lines should have little plastic buttons you need to press and then pull the line off. If you have the tools shown above which are for the internal clip designs, these can be used to aid in removal also.
4play is offline
post #6 of 8 (permalink) Old 02-19-2010, 10:33 PM
UpstateDieselGuy's Avatar
Let me say one thing, that design is great on paper, but if you live somewhere where there is snow, ice, salt, etc. good luck. I tried on my girlfriends old Explorer, fuel filter, with PB Blaster and nothing. I had my buddy do it and they had a time even on a lift trying to get them apart. Just a little rant, Chris
SOLD
UpstateDieselGuy is offline
post #7 of 8 (permalink) Old 02-19-2010, 11:36 PM
Big Stroker PSD's Avatar
I think they work great
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Big Stroker PSD is offline
post #8 of 8 (permalink) Old 02-21-2010, 04:57 AM
StrokerDude's Avatar
The quick connect tools are definately the way to go on any of those type of connections. For the few dollars it cost to buy them, you save yourself lots of headache and time... Also leaving more time for "relaxation" at the end.
Alex C.
StrokerDude is offline
FUEL TANK lines BIG C 5.9L Cummins (Pre 1994) 0 08-08-2009 08:26 PM
I have foresale a Dj fuel intisier kit with braided lines. All lines and fittings tha Robts Whats Been Sold 3 05-01-2008 11:10 PM
fuel return lines and tank IDImonsterstack 7.3L and 6.9 IDI (Pre 1994) 4 12-18-2007 04:01 PM
Tool for fuel lines at tank? Michael 1994-2003 7.3L Power Stroke 3 10-06-2007 03:37 AM
Air in fuel lines below a quarter tank Force Fed Mopar 7.3L and 6.9 IDI (Pre 1994) 8 08-15-2007 12:09 PM
