Brake Dust - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by S04X, this thread has received 2 replies and been viewed 461 times.
post #1 of 3 (permalink) Old 02-21-2010, 02:52 PM Thread Starter
Brake Dust
I had brake dust shields on my OEM 16" wheels and really liked them. I have long since changed to 18" Eagle Alloys. I have not had any luck finding shields to fit. Anyone know where I might find them?
Over the winter I have neglected to keep the wheels clean and I am now in for some work. I wish the people that say "spray on rinse off" would try it on mine, 60days of mud, snow and mostly brake dust. Any tips would be appreciated.
Thanks
2004.5 Excurson EB, 196,xxx mi.,18" Eagle Alloys with Michelin rubber, 4" MBRP Turbo back, lost kitty, Harpooned Tank, AFE Stage II, "Custom" Water Bypass Filter(you know home made), AirDog II, HFCM delete, SCT w/ Looney, Edge for gauging Boost and EGT.
S04X is offline
post #2 of 3 (permalink) Old 02-21-2010, 02:56 PM
bushpilot's Avatar
ive learned that brake dust is WORSE from aftermarket brake pads.
the shields that youre talking about are NOT a great solution, they trap
HEAT in the rotors & pads.
Don R.
Truck Audio,
bushpilot is offline
post #3 of 3 (permalink) Old 02-21-2010, 03:59 PM
Big Stroker PSD's Avatar
I buy the more expensive pads . I don't have any dust on my wheels .
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Big Stroker PSD is offline
The Following User Says Thank You to Big Stroker PSD For this addition to TDG:
bushpilot (02-21-2010)
6.4 bit the dust vs 6.7!!!!!!!!!! SOOTBANDIT Road Kill, Bench Racing 17 03-06-2012 12:51 AM
Brake dust 4rcFed General Dodge Discussion 3 10-11-2009 05:34 AM
Is there a product to put on rims to keep brake dust off? smokinIH30 The Detailing, Paint & Bodyshop 14 06-29-2009 05:46 AM
Brake dust shields... HawaiianSuperDuty General Ford Truck and Excursion 1 10-26-2007 11:45 AM
brake dust 01dezoll 5.9L Cummins (1998.5-2002) 3 06-08-2007 01:19 AM
