4 inch to a 6inch - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mattsn, this thread has received 5 replies and been viewed 944 times.
post #1 of 6 (permalink) Old 02-21-2010, 05:59 PM Thread Starter
mattsn's Avatar
4 inch to a 6inch
been brainstorming for projects to change my truck around , thinking about getting rid of the 4 inch and install a six inch lift with springs all the way around.
all the kits i look at dont show anything for brake lines, are the stock brakelines still long enough even with 6 inches ?
mattsn is offline
post #2 of 6 (permalink) Old 02-21-2010, 06:07 PM
Baldguy5.0's Avatar
My 6" kit came with aftermarket longer lines. So im going to have to say no stock lines are not long enough.
8" lift
37x13.5R20 Toyos
20" Diamos
AFE Stage 2 CAI
AFE 4" Downpipe back DPF delete
H & S Mini Max
PIAA 4000K Head and Fog lights
Alpine 505
Bushwacker FF
Custom Interior painted stuff
Recon clearance and mirror lights
Baldguy5.0 is offline
post #3 of 6 (permalink) Old 02-21-2010, 06:22 PM
fine69's Avatar
You realize this is the 2008-2010 forum right?
H-M.W.H. Club #2
Union Club #1
Singles #237
B.O.M.B. Squad #12
Ridin' Dirty Club #17
American Club #15
fine69 is offline
post #4 of 6 (permalink) Old 02-22-2010, 01:25 AM
********* and Mafia #90
Bcarriveau's Avatar
Moved to general ford!
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
The Following User Says Thank You to Bcarriveau For this addition to TDG:
mattsn (02-22-2010)
post #5 of 6 (permalink) Old 02-22-2010, 02:01 AM
6.0L Stroker's Avatar
I used to have a 4 inch pro comp lift on my truck that came with brake line drop brackets, then switched to a pro comp 6.5 inch and it did not come with anything for the brake lines, I just kept the brackets on there and then kinda bent them a little more and bent the bottoms of them and they seem to have plenty of slack in them now.
2004 F-350 cc/lb lariat. Pro comp 6.5 lift with 37/13.50/17 Toyo m/t on pro comp 6089. Mbrp straight with airaid intake and Bullydog Triple Dog and IDP FICM mild tune
New short block at 72k
As of now it has 103k
6.0L Stroker is offline
post #6 of 6 (permalink) Old 02-23-2010, 05:17 PM
I Wanna Go Fast!
brentos's Avatar
i had a 6" on mine for a couple years with stock lines and never had a problem... plenty of slack...stock lines are good up to 8" almost
brentos is offline
35 inch Toyos on 16 inch rims cash or trade. woodsman Ford Parts 7 10-26-2009 05:11 PM
4-6inch exhaust tip F2million 2003-2007 6.0L Power Stroke 30 06-03-2009 05:03 PM
4 Inch and 5 Inch straight pipes by May ???? snopro99 2008-2010 6.4L Power Stroke 27 05-05-2007 11:40 PM
6inch vs. 5inch tip JYFarmer 2003-2007 6.0L Power Stroke 3 01-15-2006 05:44 PM
Which tires for 20"s and 6inch lift???? 6point6 General Ford Truck and Excursion 10 01-05-2006 12:00 PM
