recon led mirror lights - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 03 SIX OH, this thread has received 6 replies and been viewed 967 times.
post #1 of 7 (permalink) Old 02-24-2010, 01:13 AM Thread Starter
03 SIX OH's Avatar
I just bought a pair of recon mirror lights and there's gotta be an easier way to install them than movin the glass 20 times and a ujoint.
2003 F250 Lariat. 6.0 Bonestock for now
03 SIX OH is offline
post #2 of 7 (permalink) Old 02-24-2010, 02:23 AM
I Wanna Go Fast!
brentos's Avatar
you need a pretty long flat screwdriver and move the glass back and forth...there are four or five clips cant remember for certain once you pop them out the back half comes off so there is no need for a ujoint.....it comes with instructions if you bought them new
brentos is offline
post #3 of 7 (permalink) Old 02-24-2010, 02:27 AM Thread Starter
03 SIX OH's Avatar
Thank you. I boughtem "slightly" used. So no instructions. I thought I had to remove the 3 bolts behinf the glass.
post #4 of 7 (permalink) Old 02-24-2010, 02:43 AM
I Wanna Go Fast!
brentos's Avatar
no prob.. get a flash light and shine it back in there and you will see them...just be very carefull they are brittle and will break. IIRC there are two on the outside one on the inside and one on the bottom i think
brentos is offline
post #5 of 7 (permalink) Old 02-26-2010, 04:54 PM
TxFireman1972's Avatar
From Recons Site:
Removal of Ford Superduty/Excursion Outer Mirror Covers
Instructions for Part # 264120BK & 264120CL for 2003-2007 Trucks
1. Behind the larger mirrors there are 3 clips holding the cover on to the mirror.
2. There are two upper clips and one lower clip that must be unclipped for the mirror
cover to release. ***PLEASE USE CARE WHEN PROCEEDING WITH THE NEXT
TWO STEPS SO YOU DO NOT BREAK THE FRAGILE PLASTIC TABS/CLIPS
WHICH HOLD THE MIRROR COVER IN PLACE*** - (You will have to move the
mirror side to side and up and down to gain access to the clips. The upper clips are
located about 3 inches from the top of the mirror. The one lower clip is on the side
closest to the truck and about 6 inches below the upper clip.)
3. Using a long flathead screwdriver, push down to remove the clips. (You may need a
small flashlight to see behind the mirror itself.)
4. The mirror cover will now release from the mirror.
5. Unplug the wiring harness from the light and remove the cover and light assembly
from the truck.
6. Squeeze the two butterfly clips on the inside of the light and push outwards. (Careful
not to break the three guide clips on the outer side of the light.)
7. Replace the old lights with the new RECON lights in reverse order to re-install.
8. Turn the truck on and check for proper operation of both blinkers and running lights.
Instructions for Part # 264140BK & 264140CL for 2008-2010 Trucks
To remove your factory turn signal lens you will need to locate the release clip behind the larger,
top mirror of your 2008-2010 Ford Superduty. The clip is physically behind the mirror on the
horizontal edge, just adjacent to the lens.
1. Push the top, inside of the mirror so that there is a large gap by the bottom, outside
edge.
2. You should see the release clip now and you simply need to depress it using a flat
head screwdriver. This will release the light from the mirror.
3. Remove the bulb sockets from the factory lens and then remove the bulbs from the
sockets.
4. Insert our plugs into the vacant sockets and snap your new RECON LED mirror lights
back into the mirror.
5. Test the running lights and the turn signals to ensure the plug is inserted correctly
before snapping the RECON lens onto the housing.
6. You will need to find a place to accommodate the wire inside the housing before you
snap the lens on.
If you have any questions, feel free to contact us:
[email protected] - www.GoRecon.com
2005 F350 Crew Cab 4x4
PMF Rear Leaf Spring Conversion w/2011 Leaf Springs
20" Harley Wheels 305/55/20 Nitto Terra Grapplers
ARP Studs & EGR Delete from PowerStrokeMagic w/GearHead Tunes
Amp Research Steps, MBRP
TxFireman1972 is offline
post #6 of 7 (permalink) Old 02-26-2010, 04:55 PM
Or here is the webpage:
http://www.gorecon.com/downloads.php
post #7 of 7 (permalink) Old 02-27-2010, 07:55 PM Thread Starter
03 SIX OH's Avatar
Thanks bud. I appreciate it.
magnaflow muffler and recon mirror lights brentos Whats Been Sold 0 12-31-2008 04:09 PM
Recon Mirror LED Lights fordt Whats Been Sold 5 12-30-2008 02:58 PM
Recon LED Mirror Lights HotSauce2138 Whats Been Sold 6 01-29-2008 11:45 AM
Recon Mirror Lights For 03-07 Superduty's HotSauce2138 Whats Been Sold 3 01-04-2008 01:49 AM
Putco vs Recon Mirror lights Squatch General Ford Truck and Excursion 3 11-04-2007 11:23 PM
