HELP (shifter gets stuck) while plowing - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by littlebigrig6.0, this thread has received 4 replies and been viewed 509 times.
post #1 of 5 (permalink) Old 02-24-2010, 05:26 PM Thread Starter
little big rig 6.0
I was out plowing a week ago and towards the end of the night my shifter would not come out of drive to go in reverse or park, after a while of trying to get it to move, it will move into reverse then after a little while it will go in park. So it hasn't happened again since last night, wasn't as bad though, it maybe got stock a few times and the other times it was just hard to move. Anyone ever experience this, 04 f250 psd, also I cant really pin point much, since its more hit or miss when it acts up, but as far as I can tell it happens more when im in 4 wheel
6.0l, bully dog triple pup, dual 5"bull hauler stacks, strait pipe from turbo back
littlebigrig6.0 is offline
post #2 of 5 (permalink) Old 02-24-2010, 06:53 PM Thread Starter
little big rig 6.0
wow no one's had this happen before
post #3 of 5 (permalink) Old 02-24-2010, 09:13 PM
UpstateDieselGuy's Avatar
I would start by looking at your linkage under the truck to rule that out. After that pull the cover off of the steering column and check there. Just some ideas, Chris
SOLD
UpstateDieselGuy is offline
post #4 of 5 (permalink) Old 02-24-2010, 09:18 PM
bushpilot's Avatar
ever have any problems getting it out of PARK ?
Don R.
Truck Audio,
bushpilot is offline
post #5 of 5 (permalink) Old 02-24-2010, 09:59 PM Thread Starter
little big rig 6.0
not that i remember bushpilot
Plowing with GM BROKER Work Truck Discussions 5 04-29-2008 11:18 PM
Snow Plowing caveman The Parking Lot 0 01-22-2008 05:18 PM
plowing Bcarriveau 2003-2007 6.0L Power Stroke 46 11-13-2007 10:26 AM
Plowing? hcr400ex Work Truck Discussions 42 02-20-2007 05:00 PM
