Urgent Help Needed, please read - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by littlebigrig6.0, this thread has received 26 replies and been viewed 1807 times.
post #1 of 27 (permalink) Old 02-26-2010, 11:14 PM Thread Starter
little big rig 6.0
Exclamation Urgent Help Needed, please read
My 04 250 psd, I was out plowing and got stuck. Anyways, I got the truck out and now when I press the brakes the steering wheel locks up and the brakes almost feel as if their is no fluid. I checked the fluid levels and everything looks good. Any ideas. Also to add I believe I have been having a caliper problem, not sure the truck was supposed to go in this week to have it checked.
6.0l, bully dog triple pup, dual 5"bull hauler stacks, strait pipe from turbo back
littlebigrig6.0 is offline
post #2 of 27 (permalink) Old 02-26-2010, 11:25 PM
********* and Mafia #90
Bcarriveau's Avatar
Either your power steering pump went out or your hydro-booster did!, if it steers fine untill breaks are applied id say hydro-booster!
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #3 of 27 (permalink) Old 02-26-2010, 11:35 PM Thread Starter
little big rig 6.0
Hey Bill, how bad is that, is it something I can replace or I need a shop to do it, would you know what a repair like this would cost. Thank
post #4 of 27 (permalink) Old 02-26-2010, 11:49 PM
Bcarriveau's Avatar
Its not bad at all, have to get down to the intake manifold and remove that, its bolted to the bottom of it and has one coolant line that goes to the oil cooler., take it out and weld up both big ends after flushing it out a bit and put it back in!
i blive
turbo, oil filter housing, alternator, and some other small stuff and it will be out in no time.
to pay someone to do it.. not to sure on that. Just take your time, loosen up the uppipes before removing the turbo.
To verify that it is the egr cooler, just remove the egr valve, two bolts and it will pop up with two small flat bars. if its wet inside you know thats your deal!. I removed my intake elbo to give my self more room when poping it out!
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #5 of 27 (permalink) Old 02-27-2010, 12:37 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
i blive
WTF are you talking about .... to remove the hydrobooster, you remove the two nuts that hold the master cylinder on then remove all the lines and remove the 4 nuts then from inside the cab..
2003 F250 "Pulling Truck"
hhrecovery is offline
post #6 of 27 (permalink) Old 02-27-2010, 12:40 AM
Bcarriveau's Avatar
easy arron , Dont get so worked up . I have to many pages open and reading more then one is not working out tonight and i havent even cracked a beer yet . I thought this was the thread about blowing white smoke
Since im all confused ill make sure it stays in the general for section
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #7 of 27 (permalink) Old 02-27-2010, 12:47 AM Thread Starter
little big rig 6.0
Boy Bill you almost gave me a heart attack
post #8 of 27 (permalink) Old 02-27-2010, 12:52 AM
Bcarriveau's Avatar
would have been a great egr block off mod night
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #9 of 27 (permalink) Old 02-27-2010, 12:56 AM Thread Starter
little big rig 6.0
Not the day im having, any way to tell if either is working or failing,
post #10 of 27 (permalink) Old 02-27-2010, 12:59 AM
Bcarriveau's Avatar
when the truck is running, can you steer it just fine until you put the brakes on?
when you got stuck. What kinda stuck we talking? like damage to the front end stuck?
Da Rules..Here
Dear Tequila:
The TDG TOTQ
Missing person URGENT PLEASE READ SeeYa The Parking Lot 6 03-06-2009 06:07 PM
OHV Trail users Urgent help needed! imported_STANG302 4X4 Offroad Forum 0 02-20-2008 11:08 PM
Urgent help needed: Glow Plug Issue stevenryals 2003-2007 6.0L Power Stroke 16 12-19-2007 12:42 PM
Urgent Prayers Needed SeeYa The Parking Lot 22 12-04-2007 08:12 AM
Urgent Prayers Needed SeeYa The Parking Lot 16 10-19-2007 03:57 PM
