2005 5.4L F150 leaking injectord - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by WasGas, this thread has received 3 replies and been viewed 1319 times.
post #1 of 4 (permalink) Old 02-26-2010, 11:29 PM Thread Starter
& amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; quot ;Mis s me yet&a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;q uot; George Bush
WasGas's Avatar
My dad recently had an injector go bad on his F150 and it filled the cylinder and bent a rod. Ford replaced the engine with a new shortblock now 6 months later the check engine light came on he pulled out his plugs and found two were saturated with fuel. He does not have a local dealer and is fairly remote, what should he look for?
He wants to replace all of the injectors now, what is the process for it?
Any other ideas?
AND YOU THOUGHT CARTER SUCKED
WasGas is offline
post #2 of 4 (permalink) Old 02-28-2010, 02:41 AM
fordsuperduty01's Avatar
Ford put out a warranty extension for the injectors on the 3 valve 5.4's. The coverage is extended to 11 years or 120k miles. I would say your best bet would be to drop it off at the dealer and let them take care of it. If he wants to do the job himself they are fairly simple to do. Remove the air filter housing on the top of the motor, remove the FRP sensor electrical connector on the fuel rail, vacuum line, and fuel feed line. Remove the 4 fuel rail retaining bolts and lift the fuel rail out.
2005 F-250 6.0L King Ranch FX4. 125k miles, Edge Platinum, EGR delete, MBRP turbo back exhaust without cat, an 03 turbo, and 4.30 gears.
A.S.E. Master certified automotive and light duty diesel technician.
fordsuperduty01 is offline
The Following User Says Thank You to fordsuperduty01 For this addition to TDG:
WasGas (03-02-2010)
post #3 of 4 (permalink) Old 02-28-2010, 12:19 PM
There is aslo a TSB for blowing Spark plugs out of the heads, (earlier years) as well as spark plugs breaking when removing them, ( bad angle special tool made by Ford required)
06 Ram 2500,4X4 QC Laramie,
Not that stock Canadian club member #4
dfranks is offline
post #4 of 4 (permalink) Old 03-01-2010, 09:18 PM
Mod Friendly Title
Zaairman's Avatar
Spark plugs blowing out was 1999-2001, spark plugs getting stuck in the head is the 2004-current 5.4 motors, but he's already taken his plugs out as stated the original post.
OP, take it to the dealer, it's under warranty for this. I'd call the dealer, I'm sure Ford would rather pay for the tow than a new short block...
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
f150 Jeff M Diesel Conversion 9 10-17-2009 01:20 AM
Cow VS. F150 pontiacross The Parking Lot 13 12-31-2008 07:39 PM
98 f150 Bcarriveau The Parking Lot 4 11-08-2007 06:05 AM
I just saw an 07 F150 HD... imported_LiftedBlackHD General Ford Truck and Excursion 3 06-17-2007 05:00 AM
2005 Excursion PS vs. 2005 F-series PS deb0650 2003-2007 6.0L Power Stroke 3 04-07-2007 06:23 PM
