Lifiting a 04 f350 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by PADLER, this thread has received 7 replies and been viewed 1430 times.
post #1 of 8 (permalink) Old 03-03-2010, 09:46 PM Thread Starter
Lifiting a 04 f350
My truck is in need of new tires, so I will be entertaining the idea of some 35x12.50. I understand that I will need to lift the truck in order to do this which is fine. Blocks in the rear end but how to get the front end up on the cheap. I was thinking maybe a shackle life of something along those lines. What would be the easiest and cheapest way to lift the front say 4 or so? And at what point am I going to have to worry about drive shafts and all that good stuff.
PADLER is offline
post #2 of 8 (permalink) Old 03-03-2010, 10:40 PM
Mod Friendly Title
Zaairman's Avatar
You're going to need aftermarket wheels for those tires. Should be good with a 2" leveling kit up front. Everything else is good.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #3 of 8 (permalink) Old 03-04-2010, 12:18 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
fabtech shackle and hanger kit will raise you 3.5" in the front....
2003 F250 "Pulling Truck"
hhrecovery is offline
post #4 of 8 (permalink) Old 03-04-2010, 07:59 PM Thread Starter
so what if i was to do a 2" front hanger drop, a 2" shackle lift as well as a 2" spring pack level lift. Would this work. any major problem with doing it this way. How high can i lift the truck before i need to worrk about longer drive shafts and vibe's and other drivability issues?
PADLER is offline
post #5 of 8 (permalink) Old 03-10-2010, 03:55 PM Thread Starter
SO WOULD THIS WORK? Any other ideas on how to lift the front on the cheap
PADLER is offline
post #6 of 8 (permalink) Old 03-11-2010, 01:38 AM
International350's Avatar
i just have 2.5" spring pack level kit and i run 33"x13.5"wide tires on stock 18rims and just barely have rub at full lock, if your running 35x12.5 you should be just find with leveling kit, thats if your back sits higher than front stock, if not just throw a block in the back also and with all this kiss your turn radious good by
2004 F-350 CC LB King Ranch. Under the Hood SCT w/Innovative street tunes by Eric, Hot FICM tuned by Power Hungary, custom built 4" intake with huge afe filter, Intake elbow, 3"down pipe to 5" straight piped stack, EGR block off, Zoodad Mod, CCV mod, Complete EGR delete, The Big 3 cable upgrade w/ batts under cab, Autometer pillar guages, Boost, Trans, EGT. APR studs sitting in box ready for install
Suspension 2.5inch leveling kit. Stock King Ranch 18" rims with 33inch Nitto A/T.
Truck is now pushing 134K miles an running strong.
International350 is offline
post #7 of 8 (permalink) Old 03-11-2010, 02:57 PM
That would be equal to a 4" lift, at which point you will need drop tracbar bracket, drop pitman arm, and possibly an adjustable tracbar. Front driveshafts don't become an issue until over 8" lift.
If you plan on keeping the truck for a while, do it right the first time. Consider a 4" Icon Spring lift kit. Will ride way better than using stock springs and shocks. Not the cheapest way to go in the short term, but in the long term will be cheaper when you need to replace the leafs and shocks anyhow.
2004 F-350, 4x4, SC, LB, 6.0PSD, 6spd
Changed a few things. More than some, less than others
Betaracer is offline
post #8 of 8 (permalink) Old 03-16-2010, 01:53 AM
brad's-powerstroked's Avatar
a front leveling kit is all you need on an f-350 to fit 35's,on my f-250 i have a rough country front leveling kit, and 5" readylift blocks in the back, my truck has always sat higher in the front then back, thats way i went with the 5" block vs a stock f-350 block. and i am running 315/75/16 tires on stock rims, no problems yet, and as you can see with the plow on(i dont plow like that just had to move it in the summer) no rubbing problems, and the pics with the plow was still stock f-250 blocks
ID:	25199   Click image for larger version
ID:	25200   Click image for larger version
ID:	25201   Click image for larger version
ID:	25202   Click image for larger version
brad's-powerstroked is offline
01 F350 PSD 6 spd reg cab 88K BBdiesel Whats Been Sold 2 01-14-2008 12:02 AM
02 F350 chelhugz 1994-2003 7.3L Power Stroke 6 12-02-2007 11:26 PM
New f350 KR........ fireplug45 2008-2010 6.4L Power Stroke 11 08-29-2007 05:29 AM
pcm for F350 BigDodge Whats Been Sold 0 07-07-2007 08:18 PM
04 f350 pulling a 04 f350 PSTROKER 2003-2007 6.0L Power Stroke 22 06-27-2006 04:32 PM
