4x4 won't engage - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bigking, this thread has received 17 replies and been viewed 4077 times.
post #1 of 18 (permalink) Old 03-09-2010, 12:01 AM Thread Starter
Bigking's Avatar
4x4 won't engage
Tried in engage my 4x4 tonight and nothing happens. No lights and no 4x4. I turned the truck off and on and the 4x4 lights came on then went off. I did have the cab off last week getting my head studs done. I'm thinking something didn't get plugged back in. Where do I start looking?
05' F-250, Harley Davidson #2993, True Blue
SCT X2 programmer (innovative tuned), MBRP 4in turbo back SS Cool Duals, Gutted Cat, S&B cold air intake, 2" front 1" rear lift, 325x60x20 Nitto Terra Grapplers, Stock Harley 20" rims, Line X, 20% tint all around, Alpine Linear Sub system, 4k Sylvania Silver Star lights, Zoo Dad mod, line of fire by Recon, ARP head studs, RCD EGR delete, new heads, new Turbo, dual bilstein steering stabilizers, bilstein 5100 shocks all 4 corners, truxedo bed cover, Amsoil. U.S.C.G
Bigking is offline
post #2 of 18 (permalink) Old 03-09-2010, 01:26 PM Thread Starter
Bigking's Avatar
Well I went out last night and checked all my fuses. All were fine. Started it up this morning and engaged just fine in 4x4. I was going to run it in 4x4 last night when a buddy wanted to race, so I ran in 2wd, still smoked him though, just a little less rubber on the rear tires now.
Bigking is offline
post #3 of 18 (permalink) Old 03-09-2010, 01:36 PM
bushpilot's Avatar
4x4 high range can be engaged on the fly (assuming you have ESOF).
4x4 LO range requires that the truck be in NEUTRAL w/ your FOOT ON THE BRAKE before
the transfer case will engage low range, reverse the proceedure to take the truck out
of low range.
I hope you werent racing in low range.
Don R.
Truck Audio,
bushpilot is offline
post #4 of 18 (permalink) Old 03-09-2010, 09:54 PM Thread Starter
Bigking's Avatar
No I tried both. Neither would engage last night, so I raced 2wd.
Bigking is offline
post #5 of 18 (permalink) Old 03-11-2010, 01:34 AM
International350's Avatar
I too am having same problems, its in the electrical somewhere and cant find it.
2004 F-350 CC LB King Ranch. Under the Hood SCT w/Innovative street tunes by Eric, Hot FICM tuned by Power Hungary, custom built 4" intake with huge afe filter, Intake elbow, 3"down pipe to 5" straight piped stack, EGR block off, Zoodad Mod, CCV mod, Complete EGR delete, The Big 3 cable upgrade w/ batts under cab, Autometer pillar guages, Boost, Trans, EGT. APR studs sitting in box ready for install
Suspension 2.5inch leveling kit. Stock King Ranch 18" rims with 33inch Nitto A/T.
Truck is now pushing 134K miles an running strong.
International350 is offline
post #6 of 18 (permalink) Old 03-11-2010, 10:54 PM Thread Starter
Bigking's Avatar
I figured something didn't get plugged in since I just had the cab off. So I started with the fuses. All were good. It's working now. It's PFM
Bigking is offline
post #7 of 18 (permalink) Old 03-12-2010, 12:19 AM
I got ya, yeah mine works off and on. Sometimes im getting voltage to the silenoid and most of the times i dont.
post #8 of 18 (permalink) Old 03-12-2010, 03:02 AM
Big Stroker PSD's Avatar
I had this same problem awhile back . Turned out to be a broken wire in the harness going the the motor on the transfer case . I took the harness completely out of the truck and check continuity between the two ends and found it .
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Big Stroker PSD is offline
post #9 of 18 (permalink) Old 03-12-2010, 02:08 PM
TDG Mafia Member#67
6L strokin's Avatar
that sounds like a huge PITA...
Previous Rides:
1997 F150 EC SB 4x2 xlt red
6L strokin is offline
post #10 of 18 (permalink) Old 03-12-2010, 09:13 PM
oh wow. So where does this wire go from the transfer case so i know where to unhook at the other end? Heck once i know where the wires go ill just rewire it, i do that daily at work. lol.
4 wheel will not engage Extender 2003-2007 6.0L Power Stroke 16 03-19-2009 09:37 PM
Please help, 4wd wont engage jrdragdad General GM Truck Forum 5 01-05-2008 10:19 PM
HELP 4x4 Will Not Engage!!! Snow Coming Instant207 1994-2003 7.3L Power Stroke 9 12-04-2007 11:13 PM
When to engage/When not to engage 4X4 courier1 1994-2003 7.3L Power Stroke 5 02-04-2007 01:04 AM
When to engage tow/haul? raynardo 2003-2007 6.0L Power Stroke 16 05-10-2006 02:20 AM
