6.0L Excursion will it pull a 11-13k trailer? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by WasGas, this thread has received 5 replies and been viewed 810 times.
post #1 of 6 (permalink) Old 03-10-2010, 02:18 AM Thread Starter
& amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; quot ;Mis s me yet&a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;q uot; George Bush
WasGas's Avatar
I am looking at a toy hauler and wanted to be sure my X will pull it, and can pull it? It is a triple axle and I would be using an equalizer hitch. I imagine I would have a loaded trailer weight of 11,500-12,000lbs.
Weights for trailer listed by manufacturer are:
Unloaded vehicle weight (lbs.) 7900
Dry hitch weight (lbs.) 1000
Gross vehicle weight rating (lbs.) 13000
Cargo carrying capacity (lbs.) 5100
Measurements
Exterior length 35' -11"
Exterior height 136"
WasGas is offline
post #2 of 6 (permalink) Old 03-11-2010, 12:32 AM Thread Starter
WasGas's Avatar
bump
WasGas is offline
post #3 of 6 (permalink) Old 03-11-2010, 01:41 AM
International350's Avatar
my truck unloaded weighs 8800 pounds and it will haul a 10K pound trailer with no problem at all and i have the same 6.0L that the excursion has
2004 F-350 CC LB King Ranch. Under the Hood SCT w/Innovative street tunes by Eric, Hot FICM tuned by Power Hungary, custom built 4" intake with huge afe filter, Intake elbow, 3"down pipe to 5" straight piped stack, EGR block off, Zoodad Mod, CCV mod, Complete EGR delete, The Big 3 cable upgrade w/ batts under cab, Autometer pillar guages, Boost, Trans, EGT. APR studs sitting in box ready for install
Suspension 2.5inch leveling kit. Stock King Ranch 18" rims with 33inch Nitto A/T.
Truck is now pushing 134K miles an running strong.
International350 is offline
post #4 of 6 (permalink) Old 03-11-2010, 01:43 AM
buy the way, the motor will pull anything, if you have any problem at all i would just add airbags to the back end to hold up the weight if you dont have heavy duty towing springs
post #5 of 6 (permalink) Old 03-11-2010, 02:02 AM Thread Starter
WasGas's Avatar
I have the power to pull it with the X but stopping may be the bigger issue. Can the X legally pull this much weight, I have seen alot of DOT inspections lately checking commercial vehichles, RV's, and diesel vehichles?
AND YOU THOUGHT CARTER SUCKED
WasGas is offline
post #6 of 6 (permalink) Old 03-11-2010, 04:23 PM
To try to answer your question.
I would think with proper trailer brakes and a good brake controller stopping the trailer shouldn't be an issue with the Excursion.
As far DOT they target commercial vehcles and drivers and personaly have never seen them stop a family of 5 towing a camper on vacation. Of course could be wrong but only commenting on what I see on the road. In my area they sit on the side of the word and pull over trucks/trailers or semi's doing commercial work. I should know been stopped by them three times now!
To be totaly honest as far as the X legaly being able to pull your trailer would have to say NO it would be not legal. The big hold up would be the tongue weight and the factory hitch. Could be wrong but if you go to rv.net they got a lot of self proclaimed weight police members who could go over all the numbers with you and figure out exactly what's legal and whats not.
IF it's not used for any type of commercial application I'd venture to say your fine but you may still be overweight. With an Excursion your under the 10K lb vehicle limit so the vehicle itself is not commercial. My dually is, the other two are not.
You should contact your states DOT and ask them about what laws you have to follow in respects to recreational use versus commercial use.
00 Excursion 7.3 4x4 Limited (wifes)
99 F350 7.3 4x4 Lariat crew cab DRW
99 F250 7.3 4x4 xlt x-cab
00 BMW 328CI 2dr silver fully loaded (wifes)
69 GTO 400 4spd
65 Mustang 289 (wifes)
04 and 09 15yrd PJ dump trailers
04 H&H 20ft tilt bed trailer
98 7x14 Haulmark trailer
dougger222 is offline
Excursion Trailer Sway Help!!! WasGas General Ford Truck and Excursion 32 12-18-2009 03:41 AM
08/09 excursion vcassens General Ford Truck and Excursion 51 11-13-2009 04:49 PM
look at this excursion 05dury The Parking Lot 6 08-28-2007 03:31 AM
Does anyone own/pull a Roadmaster/Campmaster or Predator trailer? bigvick General Dodge Discussion 0 07-27-2007 05:53 PM
Excursion 4cefed 2003-2007 6.0L Power Stroke 12 09-02-2006 07:12 PM
