Heated mirror turn off - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Russ7R, this thread has received 7 replies and been viewed 928 times.
post #1 of 8 (permalink) Old 02-06-2006, 06:05 PM Thread Starter
I have read until my eyes are burning here for days, but still cannot find the mod here.
I have an 06 F250 and I want to use one of my upfitter switches to turn off my heated mirrors. The reason why is my tires flip water unto the mirrors and than that become full of water spots, so bad you cannot see out of them.
So does someone know which wire needs to be switched to do this?
Thanks
Russ
Russ7R is offline
post #2 of 8 (permalink) Old 02-06-2006, 06:16 PM
Destroked
diesel dan's Avatar
I believe they are temp. controlled, in the summer I dont believe they come on...shutting them of in the winter might make the water spots turn to ice living in WI...that would be tough to see thru also.....:shrug: I know from experience driving a semi you definately want your heated mirrors on in the rain so it dries the rain on the mirrors.....:IMO..its easier to see through water spots than a wet mirror....
diesel dan is offline
post #3 of 8 (permalink) Old 02-06-2006, 06:31 PM Thread Starter
On my 03 I never had this problem with water spots and they were not heated, with these they are almost impossible to see once the water has dried on them. I think if the water would evaperate it wouldnt be that bad.
Russ
Russ7R is offline
post #4 of 8 (permalink) Old 02-12-2006, 12:30 AM
Heated Mirrors
Just pull the fuse. It would be nice to have them set up to turn on and off with one of the upfitter switches. It is true they are on all the time. Outside Temp has no bearing on their function.
Poneyxpres is offline
post #5 of 8 (permalink) Old 02-12-2006, 12:38 AM
in F series they are indeed on all the time. the only way to kill em is either do what poneyxpres said and pull the fuse or splice in a switch. i THINK (not sure) in excursions they have a switch
seeing after water is on em and they are powered is next to impossible
_CH_ is offline
post #6 of 8 (permalink) Old 02-12-2006, 02:22 AM
4cstr
I wired up a set of heated Excursion mirrors to my truck. They are indeed on all the time. You can splice into the heater element wire and put them on a switch. I did. I would think that if you can figure out what color wire runs the heater element you can cut and splice an upfitter switch to do it.
post #7 of 8 (permalink) Old 02-12-2006, 02:30 AM
Banned
wastedwagesracing is offline
post #8 of 8 (permalink) Old 02-12-2006, 04:19 PM
I have mine wired up to one of my upfitters and they work great and are on when I want them to be.
refuse2
2005 F-250 Dark Toreador Red, Lariat Lux. package, 6.0 PSD, Torqueshift auto trans, 4x4, ESOF, tow command, Sirius Satellite radio, Retrax bed cover, Kermit Coolant filter, GOS Headlight harness, Fog light High beam Mod, Heated mirrors upfitter #1, AIC Upfitter #4, Wix Powertrap , Harpoon Mod, CCV mod, Magnaflow 4" turbo back and no kitty, Oil Guard by-pass, and Schaeffers 5w40.
work trucks:
94 ford Ln8000 8.3 cummins MD3060
91 ford Ls8000 7.8 ford allison MT653
98 Freightliner FL80 8.3 cummins MD3060
refuse2 is offline
