How to minimize DRW tire wear? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by HwyStar, this thread has received 10 replies and been viewed 2746 times.
post #1 of 11 (permalink) Old 03-26-2010, 02:04 AM Thread Starter
I was trying to figure out what tire pressure to run on my 05 DRW, when the subject came up of the odd outter tire wear. I hear its because there is a steel rim, and a aluminum rim, therefore they wear differently. Has anyone just got another aluminum rim and just use all alloys? It would save all the pain with rotating, but Im not sure if it would fit on the shank on the axle with two alloys.... What about all steel? What pressure? This is new to me and I definetly don't want to be buying 4 tires before my time.
MM1(SW)-N USN CVN65 RM22
'05 F350 DRW 4x4 6L - 15.16 @ 84 mph
'04 Mach 1 - 12.94 @107.5 mph
'94 Mark 8 12.36 @ 109 mph
HwyStar is offline
post #2 of 11 (permalink) Old 03-26-2010, 03:23 PM
BillsFan's Avatar
I have not had a dually (yet) but my friend had one. He used to run with some weight in the bed to help keep the tire wear even - or so he said.
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
post #3 of 11 (permalink) Old 03-26-2010, 06:25 PM
Lots of class eight's run steel inners, and aluminum outers. it is not a problem. What you want to do is buy a good tire gauges for preasure and depth. If the tire is wearing more on the outside then the preasure is to low. If the tire is wearing more in the middle then you have to much air. You have to swap the tire side to side, and if you are loaded heavy add air and is light subtract air. You want to get a clip board, and measure the tread depth, and watch and measure. Tires to last are a maintenance item that needs continual monitoring. Just a thought!
Johnp3 is offline
post #4 of 11 (permalink) Old 03-26-2010, 09:07 PM
The Guy Mom Warned About
Fantom3993's Avatar
Send a message via AIM to Fantom3993
I don't think I've ever had a dually where the duals wore at different rates
John - 2004 Harley F250 Black/Competition Orange All the factory goodies, '05 Black Harley Headlights, Silverline 4'' Duals W/5'' Chrome Tips, Edge Platinum, Sirius Satellite,Pioneer AVIC D3
2001 Ford F550 XLT, Torreador Red,
7.3 Diesel, auto trans. chrome 19.5's
Rugby Dump Body, painted to match.
2004 F250 Reg Cab Long Box XL. Upgraded chrome grille and clear headlights from '04 Harley. Lariat Alloys and Factory CD/Cassette (Totaled 10/2/09)
1995 F350 Crew Cab Dually XLT, 460 Gas hog.
Fantom3993 is offline
post #5 of 11 (permalink) Old 03-26-2010, 09:47 PM
Bigrigs's Avatar
Yeah man..Agreed
Alum and steel wheel has nothing to do w/wear...proper inflation and side to side rotating does....I don't drive mine as much as I used, but I would always swap sides every 5k miles or so...check tire pressures weekly, I and watch/feel the tread for wear patterns, I have 71k miles on the truck, tows a 30' camper or 24' car/toy/whatever trailer and I only am on my second set of 6 tires...replaced originals at around 58k, my one buddy makes fun of my "OCD" on my truck but he's on his fourth set at 88k miles
-SOLD-04 F350 CC DRW 6.0PSD...ARP studded & Elite full delete : DieselSite coolant filter : RED ELC SCT X3 by Innovative & Gearhead : Custom built all Billet 5R110 : Diamond Eye 4" duals : zoodad & ccv mod : guages and more gauges
Bigrigs is offline
post #6 of 11 (permalink) Old 03-27-2010, 02:16 AM
Crossfire's, they keep the pressure the same between inners and outers, running with the sun shinning on the outer can raise the pressure 10#.
Check the circumfrence (stagger) within 1/8 th inch
Make sure the wheels are centered and true.
81 Isuzu /C223na, 5spd
keydl is offline
post #7 of 11 (permalink) Old 03-27-2010, 11:39 PM Thread Starter
Thanks for the advice. Did the CROSSFIRE that you mentioned put the tires out of balance? I like idea since its hard to check the press on the inside tires.
HwyStar is offline
post #8 of 11 (permalink) Old 03-28-2010, 04:33 PM
Crossfires don't show problems on 24.5 wheels, and I don't run the GMC fast - generally 60.
They solved the worming wear problem on the trailer tires, and have saved several tires from underinflation. Running underinflated is the normal cause of zipper failure of either if a pair of duals. The overloaded tire or the underinflated tire.
Mounting tires without correct stagger drags the smaller tire by the difference every turn and overloads the larger tire.
keydl is offline
post #9 of 11 (permalink) Old 04-05-2010, 06:23 PM Thread Starter
What exactly do you mean by the correct stagger?
HwyStar is offline
post #10 of 11 (permalink) Old 04-05-2010, 06:31 PM
Administrator
fordt's Avatar
Images: 5
A staggered setup would be a different size tire on the front than on the rear. Atleast this is how I know it to be defined.
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
Dually - Tire wear question Black06 2008-2010 6.4L Power Stroke 3 10-19-2009 12:57 PM
Abnormal tire wear Cincinnati Guy General Ford Truck and Excursion 10 04-13-2009 01:29 PM
Tire Wear Issue w_huisman General Ford Truck and Excursion 11 03-26-2009 12:53 PM
Diesels and tire wear... StrokerDude 1994-2003 7.3L Power Stroke 56 10-25-2007 04:48 PM
Strange tire wear??? ACC inc. Towing and Hauling 5 10-31-2006 12:28 AM
