transfer case help & trani fluid? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TYRED, this thread has received 2 replies and been viewed 688 times.
post #1 of 3 (permalink) Old 03-31-2010, 07:59 PM Thread Starter
I changed my t case fluid, and when i was draining it i also undid a large nut next to the electric t case shift motor thinking it was another drain. its not. a spring and a little cup thing fell out. what is the correct way to put them back in? it looks like the spring goes in the cup goes in the bolt and the spring puts pressure on something in the t case?
And to drain the manual trans do u just remove the inspection cover? i dont see a drain plug. And what size is that square fill plug? thanks
TYRED is offline
post #2 of 3 (permalink) Old 04-02-2010, 02:47 AM
What year and what are you driving? The drain plug is normally on the lowest part and its the same as the fill plug.
2006 yamaha Vmax
2003 suzuki 1000 GSX-R
1993 F-250 460
Near GP alberta.
CC#58
budtoh3zo is offline
post #3 of 3 (permalink) Old 04-02-2010, 06:21 AM
4play's Avatar
I would assume you an 04 truck with the shift motor on the front of the case beside the front driveshaft. Its a New Venture T-case BTW and takes regular MERCON ATF
Here is how the pieces go back in. first piece back in is the poppet, which your calling a cup, The smaller tipped end of the poppet goes into the case first, the spring goes into the opening "cup" of the poppet. Make sure the O-ring stayed on the plug and is in good shape and install plug. To sum it up again. Poppet/cup in first, spring, then plug.
4play is offline
Transfer Case Fluid Slick Willie 2008-2010 6.4L Power Stroke 7 08-24-2009 03:39 PM
Transfer Case Fluid Confusion merlin5577 General GM Truck Forum 7 07-28-2009 04:36 AM
Change that transfer case fluid!! 4cstr General Ford Truck and Excursion 39 06-09-2009 04:09 PM
Transfer case fluid jeffro22 2003-2007 6.0L Power Stroke 2 01-16-2009 03:18 PM
Transfer case fluid?? jschall 2003-2007 6.0L Power Stroke 4 06-05-2006 10:34 PM
