AC compressor not working - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 01PlatinumEdit, this thread has received 5 replies and been viewed 14089 times.
post #1 of 6 (permalink) Old 04-01-2010, 08:32 PM Thread Starter
01PlatinumEdit's Avatar
Anyone have experience with the AC compressor going out? I haven't turned the AC on in a few months and now that the weather is warming up I need it, but the compressor clutch doesn't engage when I turn the switch over to any of the AC settings. Have checked fuses, diode, and harness connections - no joy. Have not checked yet for power at the compressor and will do that tonight. Has anyone been down this road??
01PlatinumEdit is offline
post #2 of 6 (permalink) Old 04-02-2010, 02:45 AM
yup been there. get your refgernt checked, if your low it will not work.
2006 yamaha Vmax
2003 suzuki 1000 GSX-R
1993 F-250 460
Near GP alberta.
CC#58
budtoh3zo is offline
post #3 of 6 (permalink) Old 04-02-2010, 06:40 AM
4play's Avatar
You can check for voltage at the compressor, but if no voltage at clutch there are a few other switches that are not allowing compressor engagement. It could be low enough on refrigerant due to leak. or a switch/wiring problem.
A few of the more prone area for problems are Weak clutch field ( with eng running an a/c on tap front of clutch hub and see if it engages, or if you have power and ground at compressor then clutch field is bad) wiring at the low side cycle switch check for breaks in the wires ( seen a few broken wires with insulation still attached. Both switches in a/c system should have and flow power through them if a/c is charged ) Check for a/c line rubbing CAC tube. Check compressor for dampness/oil traces ( signs of leakage )
4play is offline
post #4 of 6 (permalink) Old 04-02-2010, 10:40 PM Thread Starter
I jumpered around the AC clutch pressure switch last night and the compressor comes on. So then using the gauge from a refill refrig can I check the pressure and there's nothing. So somehow I lost pressure over the winter and now I guess I'm chasing a refrigerant leak. Thanks for the info.
post #5 of 6 (permalink) Old 04-03-2010, 04:11 PM
The front seal on the compressor needs oil to work, the refrigerant pressure pushes it out so you have to run the compressor for a couple minutes every month to circulate the oil.
If the pressure is under 15# you might want to vacuum the system before recharging, you start with an accurate charge and no air.
It may have a leak someplace else - the pressure would normally go to 0.
81 Isuzu /C223na, 5spd
keydl is offline
post #6 of 6 (permalink) Old 04-05-2010, 03:43 AM
4play's Avatar
Yep, more than likely a leak. I suggested a few problem areas for leaks in post #3 that i have seen. If the leak is fairly fresh, or you charged it up, then look for a fluroescent green oil leaking out somewhere. If it an old leak you will usually see an oily substance/residue on the A/C components and lines. look close at the line connectors, or possible rubbing spots. front hub of compressor. Also check the condensor behind the grill, have seen rocks/debris hit the condensor causing leaks too.
4play is offline
ISX Air compressor legend10 Medium and Heavy Duty 4 10-17-2009 03:22 AM
A/C not working at idle, compressor not cycling rapidly paulkeith General Ford Truck and Excursion 6 07-31-2009 01:40 PM
Air compressor HP Freak 5.9L Cummins (Pre 1994) 2 06-09-2009 04:57 AM
Need an A/C compressor Bone stock 99 Whats Been Sold 0 05-22-2009 10:57 PM
A/C compressor akcopterman 1994-2003 7.3L Power Stroke 1 05-28-2007 05:43 AM
