Low tire pressure warning light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ERTERT222, this thread has received 7 replies and been viewed 971 times.
post #1 of 8 (permalink) Old 04-03-2010, 09:25 PM Thread Starter
Light and message came on. Tires are OK. Just happened. It's staying on, won't go off.
Its under warranty but I don't want to blow a day bringing it in to the dealer.
Has this happened to anybody?
ERTERT222 is offline
post #2 of 8 (permalink) Old 04-04-2010, 12:07 AM
bigastrk's Avatar
It could just be a slight pressure difference in the tires. I want to say that if its like 2/3 lbs off on one tire from the rest it will trip the light. usually if mine come on I check the tires and just drive it and it will go off. If it doesn't go off check the pressure and go from there. You could also probably go to a tire shop and ask them to reset the sensors for you.
03 6.0L Excursion < Sold
bigastrk is offline
post #3 of 8 (permalink) Old 04-04-2010, 12:35 AM Thread Starter
I checked pressure in all tires with two guages. Dial and digital. They are with in 1 psi of recomended pressure. (65 psi).
I am not conerned about 1 lb. 5-10 OK something needs attention.
Is it that sensitive?
post #4 of 8 (permalink) Old 04-04-2010, 01:32 AM
Should not be that sensitive, 10% to 25%.
A well trained tire dealer should have you fixed in 1/2 hour or know that the parts are worth the trip to the dealer.
81 Isuzu /C223na, 5spd
keydl is offline
post #5 of 8 (permalink) Old 04-04-2010, 02:44 PM
BillsFan's Avatar
This happened on Jeep Grand Cherokee we had, no matter what the pressure was that stupid light came on. Took it to the dealer who diagnosed a bad sensor in the wheel. $85 later it was fine. Also check your spare, that was the first thing they told us to check as it had a sensor also.
I'm glad I don't have those on my truck . . .
What are you driving by the way?
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
post #6 of 8 (permalink) Old 04-04-2010, 02:47 PM Thread Starter
2010 F250
post #7 of 8 (permalink) Old 04-04-2010, 10:53 PM
BillsFan's Avatar
Take it back and say
Ridin' Dirty #64
BillsFan is offline
post #8 of 8 (permalink) Old 04-05-2010, 03:32 AM
4play's Avatar
More than likely its a sensor problem, whats the message saying?
If it says something like "tire pressure sensor fault" or "tire pressure monitor fault" then you have a problem with the sensors or something else in the system.
4play is offline
correct tire pressure for 37x13.50x20 toyo tire skter97 General Ford Truck and Excursion 15 11-02-2009 06:25 PM
Check tire pressure warning AJG516 2008-2010 6.4L Power Stroke 36 04-13-2009 03:14 PM
Fuel Pressure Warning Light? NCfarmboy 2003-2007 6.0 Tuner Forum 6 02-03-2009 05:53 PM
TPS Warning Light wolfeyes89 2008-2010 Body & Suspension 37 01-23-2009 03:44 AM
HELP! ABS Warning Light TowRig General Ford Truck and Excursion 3 04-15-2007 06:37 PM
